View Poll Results: Do you use tie down straps?
I use straps AND a safety chain
225
72.58%
I JUST use a safety chain and winch
41
13.23%
No straps, No safety chain, just a winch
25
8.06%
Allan4 is a putz
19
6.13%
Voters: 310. You may not vote on this poll
Who uses Tie down straps
#91
sleeper,
I don't have a direct path from the transom eyes to the trailer either; however, I fold the strap lengthwise, and it passes through the edge gap between the K-plane tab and the K-plane mounting plate. It works well, and little to no fraying. Contact OSO member WarParty36. He owns a company called Process Manufacturing out of the midwest, and he has supplied many an OSO member with SERIOUS straps and winch straps. I bought 4 transom rachet straps from him, (two transom, one used on bow eye, and one spare) and a new wider winch strap. Its quality stuff. Do a search and you will find his info.
#93
I have always used them on my previous boats but I havnt found a good way to do it with my 27 Fountain. The tabs are in the way. If I run some straps from the stern eyes to the trailer it would put a lot of sideways stress on the tabs. Any ideas?
#94
On my 28 AT the straps ran past the tabs too. I didn't think it was a big deal, most of the strap was touching the transom plate & the hull. It may ride differently in your application, but my guess is that it would be fine; those tabs are pretty tough.
#95
Originally Posted by sleeper_dave
.........There are two eyes on the transom, but when i hook the other end to the trailer it interferes with the trim tabs. When i have to tow long distances, i put them on, but they start to fray right away from rubbing on the edge of the tabs.......
#96
I bought some inexpensive straps with a nice high strength rating, and wrap them around the bunk and strap to the eyes on the back of my 27' Fountain. They interfere with the tabs, and put some sideways pressure on them, but no where near the pressure of landing at 40 mph with the tabs down, i figure. The way i wrap them around the bunk and hook the strap back to itself is starting to fray the strap, but it should be okay for a couple seasons, i figure. Then i'll just replace the straps.
At the front, i replaced my winch post with one rated for 12,000 lbs (boat + trailer + fuel only weighs 7100), and replaced the whole trailer tongue with a thicker, larger version. I hook the front up with the winch strap and safety chain, then i run another strap from the bow eye to the back of the tongue, holding the front of the boat back and down on the trailer. That should keep the front of the boat on the winch post in the event of a collision, and between the winch post and the strap it should keep the boat off the truck, also.
Personally, i'm not going to try to jump any kind of ditch with my truck, if someone pulls out in front of me and does something stupid. If it's your fault i'm crashing, i'm crashing INTO YOU. I'll make damn sure your names on the police report somewhere. It's a lot easier to convince the insurance company that it wasn't my fault if i'm not the only one involved in the accident. If i'm for sure going to crash, the only consideration left to take is trying to aim away from the passenger compartment in any side impact.
#97
On my trailer, my bunks are further outboard, so the boat sits further down in between the bunks. I think yours is supported better, but mine has a lower CG and the chines will catch on the bunks to prevent any lateral movement in the event of trailer sway. In your case, i'd install two more tie-down eyes directly over the bunks, and wrap the strap around the bunks at one end.
#98
Originally Posted by BADKACHINA
Could anyone give a good enough answer why NOT to use them?
#99
#100
Originally Posted by OldSchool
It takes way too much time to put them on!!
Anywayz, I have it setup so as soon as I remove them from the boat, I clip the loose end to the trailer for launch and retrieval, and then clamp them right back onto the transom rings before towing again. Its a lot less hassle then pulling them completely off and sticking them in the truck.
