View Poll Results: Do you use tie down straps?
I use straps AND a safety chain
225
72.58%
I JUST use a safety chain and winch
41
13.23%
No straps, No safety chain, just a winch
25
8.06%
Allan4 is a putz
19
6.13%
Voters: 310. You may not vote on this poll
Who uses Tie down straps
#41
Originally Posted by BURNSMAZZ
It takes a lot to dump one of these things off the trailer,what in the hell was the guy with the Fountain doing? There had to have been a sharp curve,someone pulled out in front of him, something **** doesn't just happen like that. If you've got the bow secured tight and you are not driving like an idiot on a road full of holes and 90 degree curves that boat shouldn't go anywhere.
most people dump them near the ramp...
#43
I figured if I found some tie downs that were easy to use, I would use them more often. I found a heavy duty set of the type where the ratchet/reel attaches directly to the trailer frame at Bass Pro Shops, similar to what the bass boaters use.
They were easy to install, and they are always "right there".
All my buddies think they are easy to use and look pretty cool.
AND, now I use them all the time because they are right there in your face when you pull the drain plug at the ramp.
I don't use anything similar up front, just the winch cable.
I would if I could find something that would stay with the trailer and worked like the rear ratchet straps.
Seeing all these nice boats laying on the road and in the ditch is starting to me nervous.
Regards,
Steve
Regards,
Steve
#45
Rented a boat on a trailer in Lake Powell. First time I ever trailered a boat and had real problems getting the boat on the trailer at the end of a boat camping trip while other boaters yelled at me about taking too long at the ramp.
On the drive home the boat was bouncing horribly on the trailer the girl gave me, so I pulled over and used a hundred feet of rope I bought with me from NY to lash the thing down with every inch. On arrival at the rental agency, the surprised manager said "what, that trailer is for a smaller sized boat, I am amazed you got it on." The road did take a chunk off the outdrive though, which I did not have to pay for.
#46
#49
Originally Posted by Waterfoul
Are you the Zuperman Zuckerman?
I've just got a little single engine 28' Nordic with a HP575.
Zuperman would probably use my boat for a yacht tender
.............................Regards,
Steve
#50
At first I didn't use transom straps. Until one day I ran over a particularly rough section of road. The boat bounced around so much that wound it leaning around 10-20 degrees to port once the road smoothed out. I had no way of righting it with out taking it back to the water.
Now I have transom and bow straps.
I used to take the winch cable and safety chain off before launching to save time. Until I once saw the bow bounce high enough to make me think it was going to slide off the trailer.
I now have a quick release sailing shackle with a line running into the truck cab. Once the boat is floating I pull the line and the safety chain drops free without having to get out.
