need help
Old 05-29-2005 | 05:11 PM
patricklhill's Avatar
Default need help
The new white base coat of paint is on, and am starting to put every thing back together. Started with the new trim tabs, then replaced the grimble bearing. Installed the transom plate then the p/s unit, thats when every thing went to hell. Tighten the p/s, I cracked the transom plate. The problem is, do I try to get it welded, or replace it, and if so does anybody have a used one I can buy.
Patrick
Attached Thumbnails need help-new-white-paint.jpg   need help-trim-tabs.jpg   need help-transom-plate.jpg
patricklhill is offline
