Need Some Technical Feedback on These Props--Again >
Old 06-05-2005 | 12:21 AM
Poorsche's Avatar
Default Need Some Technical Feedback on These Props--Again
I was re-organizing my garage and found these "cleaver" like props. I've currently got 21P Mirages on a Formula SR357 and I'm only getting 4000RPM at wide open throttle.
Can anyone predict what some of the effects of putting these props on will be? Pic is of just one of the props--gona put LH and RH on TRS drives.
I think my new drives are longer than the ones I replaced and X-dimension is "longer".
Thanks for any comments.
Attached Thumbnails Need Some Technical Feedback on These Props--Again-cleaver21p.jpg
Poorsche is offline
Old 06-05-2005 | 06:15 AM
Dave M's Avatar
Veteran: Navy
Default Re: Need Some Technical Feedback on These Props--Again
A friend had a prop like that on a small Checkmate. I think the person he bought the boat from just put it on there to get rid of it. It did not run that well. He switched to a Mirage Plus and picked up 5+ MPH. I think they only run good on certain boats.
Dave M is offline
Old 06-05-2005 | 06:51 AM
OldSchool's Avatar
It'll take you 5 minutes to swap them out with the other props at the ramp. Try 'Em out!!!!
OldSchool is offline
Old 06-05-2005 | 02:13 PM
Poorsche's Avatar
Gave the change out a try--adn might know--the thrust washer for MIrage is totally different than for the cleavage prop.
Now to ID the correct thrust washer and another shot at it.
Poorsche is offline
bezdikjack
9
06-20-2005 02:50 PM
Poorsche
3
07-29-2004 09:49 AM
Ratchet
1
01-23-2004 06:19 PM
Shane
1
06-17-2002 01:46 PM
Shane
06-17-2002 09:40 AM
