-   -   Speedmaster lll Tools Wanted (https://www.offshoreonly.com/forums/general-boating-discussion/105210-speedmaster-lll-tools-wanted.html)
autoap 06-09-2005 03:32 PM
If anyone has or knows of any Speedmaster lll tools for sale or rent please contact me: [email protected]... I need to replace my prop shaft seals.
Thanks in advance,
Mike
Reed Jensen 06-09-2005 05:19 PM
Re: Speedmaster lll Tools Wanted
I have the tool that takes the nose cone off.... You can use industrial type spanner tools on the inside to take it apart. I did mine. OH... by the way... you don't have to totally disassemble the drive to remove the prop shaft and change the seals. The trick is to slide a shaft the same diameter as the prop shaft into the gears to keep everything in place. It also helps if you have a fixture that holds the drive and the prop shaft vertical. Reed [email protected]
Reed Jensen 06-11-2005 06:09 PM
I hope nobody TRIPS over this thread........... :D
