Intercoolers for 1471 blower motors- Worth the money?
wondering if installing intercoolers on a blower motor with increase life of motor, and does it increase hp and performance or just allow you to run more boost? thanks- who makes the best one for the Blower shop 1471?
Re: Intercoolers for 1471 blower motors- Worth the money?
Yes they are a must..they cool the air after it is compressed.
Fred looking for 3 for my 50 nortech, whaat brand do you recommend, also do they come with the hoses and plumb kit,. thanks Jim midwest performance marine --loto
I'm no expert but I would say any blower motor should have an intercooler, not only is it cheap horsepower but cooling your intake charge helps with detonation among other things. Could anybody make an argument not to have an intercooler?
If you use psi blowers you don't need them
3 Attachment(s)
I do not know about 1471's but I can tell you what happened when i added chillers on my B&M 420 Mega Blowers.
1. Fred sold them to me and his service was as good as his incapacity to get that Sutphen wet... in other words.... AWESOME SERVICE. 2. Originally I ran 6# of boost and the boat ran everyday 78.5mph with taps at 80.3 when only fumes left in the tank and two on board. All this on fresh water. 3. Added the chiller the boost is down to 4.8-5# due to the larger intake area but I see 80's consistently. I have not changed my props yet but will do so soon. I also am ordering pulleys to get the boost back up to 6#. I imagine it will give me 82's day in day out with light runs close to 84. Again all in fresh water. 4. I would be carefull of flushing those systems religously if you use them in salt water from related experience to me by multiple world champion of cores rotting out in salt water enviroment. For me it is a non issue. 5. I installed them myself without any hitched and I am an idiot so they are pretty easy to put on. You'll need belts 8" longer also. All I need now is get the bling bling hose fitting and right lenght braided lines but the setup is sound currently and the boat runs like a raped ape. My evaluation is easily 40-50hp per mills in my application once the boost will be back to the original setting. This crap is on a 2000 42 Cigarette Tiger with 509's CR 8.1. Hope this helps. |
trick, do you sell weiand 256 supercharger kits? Im considering installing them on the cig this winter. could i keep a single holley dominator carb or would i need two carburetors?
any time you compress air,you also heat it,even with a psi,the psi by design makes less heat,but still will benefit from cooling the air charge.:evilb:
| All times are GMT -5. The time now is 12:21 PM. |
