-   -   1983 Formula 26 Sc Express (https://www.offshoreonly.com/forums/general-boating-discussion/106868-1983-formula-26-sc-express.html)
RJH10 07-02-2005 06:28 PM
GREETINGS TO ALL ,, NEW TO THE SITE AND ENJOYING EVERYTHING SO FAR... I RECENTLY PURCHASED A 1983 FORMULA 26 SC EXPRESS .. IT HAS BEEN SITTING ON A TRAILER IN A BACKYARD FOR OVER 15 YEARS.. PRETTY MUCH EVERYTHING WILL NEED TO BE REDONE.. BOTH MOTORS AND OUT DRIVES ARE SHOT, AND WILL NEED TO BE REPLACED .... THE HULL IS IN GREAT SHAPE THOUGH ... I WAS CONSIDERING PUTTING A ENGINE BRACKET ON THE BACK OF THE TRANSOM AND HANGING A COUPLE OF 200 / 250 4 STROKE OUTBOARDS ...
HAS ANYONE EVER SEEN THIS DONE TO A FORMULA ?? I HAVE CONTACTED FORMULA ABOUT GETTING INFO ON DOING THIS ,,, NOT MUCH COULD BE FOUND THIS MODEL BECAUSE OF ITS AGE .... ANY INFO ON THIS SUBJECT WOULD BE HELPFUL.....I KNOW THERE A MANY THINGS TO CONSIDER ,,, DOES ANYONE KNOW IF THE TRANSOM ON THE FORMULA'S ARE SOLID CORE ? OR ARE THEY JUST BUILT THICKER WHERE THE OUT DRIVES COME THROUGH ?? THANKS ONCE AGAIN & GOOD LUCK BOATING TO ALL !!!! :cool:
cuda 07-04-2005 12:19 AM
Re: 1983 Formula 26 Sc Express
The transoms are plywood cored.
pablogueller 02-18-2012 09:49 AM
Graetings form Argentine:
I have foun this: http://www.engravingsvc.com/formula/...20Brochure.pdf
I do not know if you can help.-
I have in argentine This: can you helpme with this model ?
I think it's a 26 sc
1) http://vehiculo.mercadolibre.com.ar/...casco-1996-_JM
2) http://vehiculo.mercadolibre.com.ar/...bird-26-80-_JM
