-   -   New!!! Konrad 540 Bravo conversion (https://www.offshoreonly.com/forums/general-boating-discussion/109271-new-konrad-540-bravo-conversion.html)
Semper Fi 08-04-2005 10:40 AM
Re: New!!! Konrad 540 Bravo conversion
Good luck with these....I hope you deal a serious wakeup call to Merc. to lower their REDICULOUS PRICES :D
tomtbone1993 08-04-2005 12:48 PM
other than lasting longer, what preformance gains would you see over bravos, without boxes?
Audiofn 08-04-2005 02:43 PM
Looks cool. Any plans for an extension box for the other drives? (ie. TRS)
Jon
Biggus 08-04-2005 02:53 PM
Yes, we already offer several other extension box systems with up to 14" of set back.
Hydrocruiser 08-04-2005 03:43 PM
Hey ...a monopoly is good...saves time deciding :D
Quiet Storm 08-04-2005 04:29 PM
I have XR's with boxes. Would I loose speed if I switched to Konrad's? I was told the transmissions would take from 5-7mph off the top speed.
The boat is a 386 Sonic, 650hp 575 SCi's
mtm 08-04-2005 04:31 PM
Biggus, Is there a shift able drive? no trans required to follow soon too
Biggus 08-04-2005 04:43 PM
The transmissions are 1:1, the only loss from spinning the tranny would be from the viscous drag of the fluid and that's only a couple qts. No way could you lose 5-7 mph there.
I'm not sure about the speed issue. The 540 HP lower is extremely efficient hydrodynamically. The was much R&D put into the development of this lower.
You would be adding some weight over the existing Bravo package. A rough guess per side would be @ 130 lbs/side.
Biggus 08-04-2005 04:49 PM
mtm,
Yes, we have been working on a shiftable drive. At this time we have a working prototype and it's proved to be extremely durable but it's a long way from production.
Kurt
MnHowardCat 08-05-2005 05:56 PM
Originally Posted by Biggus
mtm,
Kurt
Do you need a local boat to do water testing I would volunteer to try a set The shiftable drive is going to be the ticket I'm interested
Don
