Starboard
Old 08-28-2005 | 08:40 PM
Ed
Thumbs up Re: Starboard
What you guys are looking for is PVC board, not Starboard, in any version. Starboard & all the other brand versions of it, are high-density polyethylene. As noted previously, it cannot be chemically bonded with any type of glue. It can only be mechanically fastened with screws, through-bolted, etc...PVC is what most quality marine upholstery manufacturers have replaced their wood with, beginning about five years ago. It can be glued with conventional PVC cement, takes a staple well, & can be worked with conventional wood-working tools. It can also be sanded, heated & formed, unlike high-density polyethylene. Its light weight is probably it's best attribute though. It can be purchased in 4' x 8' and 4' x 10' sheets, in 1/8", 1/4", 3/8", 1/2" & 3/4" sheets at any wholesale plexiglas or plastics house. It is available in a couple different grades, depending on the quality of the finish you desire. The smoother the finish, the higher the price. You don't need the smoothest finish version, unless it is exposed on the bottom of a cushion, etc... It is available in white, gray & black...white being the most popular. Farco Plastics is a good source, so is Piedmont Plastics. Hope this helps. Ed
Ed is offline
Old 08-28-2005 | 09:03 PM
mr_velocity's Avatar
Default Re: Starboard
Originally Posted by woogie
I have used Buck Woodcraft in Marathon Fla. John Arbuckle. Here is link:http://www.buckwoodcraft.com/king_starboard.htm
Sells 6 colors of Starboard in sheets and by sq.ft. Ships same day. The adhesive most use is 3M Scotch Weld DP8005. Use a real a top quality router bit.
Has a lot of great information on the site but he's a little pricey.
mr_velocity is offline
Old 08-28-2005 | 09:26 PM
HDPE (high density polyethylene) can be formed if heated to about 300 degrees and holds its shape much better than starboard, which needs to be heated to about 500 degrees to be formed. Starboard is pure, Starboard XL is recycled material. Either starboard holds a staple fairly well as long as the pull is perpendicular to the staple, if the pull is vertical it does not hold well unless 1/2" staples are used in 1/2" material, even then it is marginal. The HDPE is about twice the weight of starboard. Forget about gluing, screw it.
Bob
Bilt-Rite Uph.
bkns84 is offline
Old 08-28-2005 | 10:10 PM
cuda's Avatar
Does it resist bending in heat as much as starboard does? I'm wanting to make a sunpad, but I know it will warp from the heat unless I build something below it, which defeats the purpose of the starboard.
cuda is offline
Old 08-29-2005 | 08:11 AM
Bob
Bilt-Rite Uph.
Weight is my biggest issue especially when adding it north of the CG.
DiamondPerformance
Skater
4
03-15-2008 12:38 PM
FormulaM2Formula
01-19-2008 08:52 AM
srl520
01-09-2008 09:42 PM
Pure Energy
03-19-2004 06:35 AM
