Which OCTANE fuel provides the best performance in your 525 EFI's >
View Poll Results: OPTIMUM 525 EFI Performance
87 OCTANE
37
75.51%
89 OCTANE
8
16.33%
91 OCTANE
3
6.12%
93 or HIGHER
1
2.04%
Voters: 49. You may not vote on this poll
Old 09-29-2005 | 01:49 PM
LIOPA's Avatar
Default Which OCTANE fuel provides the best performance in your 525 EFI's
Just curious to see who runs what octane for top performance.
All comments welcomed............
LIOPA is offline
Old 09-29-2005 | 02:23 PM
jdnca1's Avatar
Default Re: Which OCTANE fuel provides the best performance in your 525 EFI's
Don't know about the 525's, but the 500EFI's run much better on 87 than 93.
jdnca1 is offline
Old 09-29-2005 | 02:34 PM
Downtown42's Avatar
87 burns hotter quicker
Downtown42 is offline
Old 09-29-2005 | 02:40 PM
pm203's Avatar
Spoke to Mercury last week about that ,and synthetic oil w/the 525. 87 octane is recommended.Anthing over 89 can actually hurt performance.As far as syn oil,they cannot endorse it as this time.Said that they have experienced some oil pressure problems with it.
pm203 is offline
Old 09-29-2005 | 03:06 PM
LIOPA's Avatar
YUP....that on going SYNTHETIC debate......Heard the same from Mercury as well about some oil pressure problems with it.
LIOPA is offline
Old 09-29-2005 | 03:28 PM
Strip Poker 388's Avatar
Rob
I allways heard 87-89 was better??
Strip Poker 388 is offline
Old 09-29-2005 | 03:44 PM
Chris288's Avatar
The higher the octane the slower it burns,,, you would only require higher octane on a higher compression motor where, pre-ignition or detonation is possible. It slows down the combustion process so the cylinder actually fires when the spark plug fires. Running 93 it in a motor that does not require it is a waste of money and will decrease performance.
Chris288 is offline
Old 09-29-2005 | 06:31 PM
offshoredrillin's Avatar
ditto, octane controls the burn is it, I run 87 and my 500EFI's run great... for oil i switched to 20W50 mobil 1, pressure is back up and consumption slowed tremendously, just a quart every couple weeks as it was a quart a week.
offshoredrillin is offline
Old 09-29-2005 | 07:32 PM
I have the 525EFI, 87 works best. I think mobil 1 one V-twin or the mobil 1 15-50 weight is best. Seems to burn less oil and keeps oil pressure higher when hot.
nitro/max is offline
Old 09-30-2005 | 06:20 AM
I use the 87.....it runs the best..but if 89 is the only thing they have, I go with that. Keeps you from having to search out higher octanes
enticer is offline
