XR Nose cone or no nose cone???
Originally Posted by BBB725
Regular IMCOs, It was a triple engine set up and only three blade props would work, 4 and 5 blades had to much blade area in the water and had porposing issues. The IMCOs cleared up the blowout issue over 100mph. Also the water intakes were smaller and helped with water pressure.
Originally Posted by FASTERDAMITT
I started with a lefty. Now I have a right hand 30 Bravo1.
switching from Lh to Rh rotation. or was there a reason ?
Originally Posted by littledcsrodshop
Not trying to jack your thread but was there a reason for
Once I get up to 50mph or more I don't feel any effect from this. I also found that the depth of the prop makes a difference. I can use the trim to balance the boat at low speeds also. Of course trim tabs are made for this but I prefer not to use them.
Also what power are you running ? single or twin ? what size
boat & weight ?
boat & weight ?
You mentioned depth of the prop. What is your X-dimension? My boat was purchased as a bare hull and rigged elswhere. My X-dim is 1.5" higher than the factory. Thanks
bbb725 what kind of boat do u have? i have a 42 cig wit trips and nose cones onteh drives and 4blades but it has a porpoising issue over 70mph...thot it was interesting how u said the three blades helped porpoising issue
37 Ourtlimits, With 4 blades I had so much blade area in the water that once the props would start lifting the nose higher until the boat would push back against the props and they would slip, or the boat would porpoise, 27 three blades came with the boat and have tried both 4 and 5 blade with the same effect. I ended up with 29 mirage plus. Boat is now twins pulled the third motor and drive. Also there was certain speeds the boat didn't want to be, Between like 70 or 80
faster,
Everything I have read about the nose cones or actually sportmaster lowers say 90mph is the switching point. at speeds below 90 don't use the sportmaster lower will lose speed. above 90 mph the sportmaster lower is suppose to be 2-3 mph faster.
Don
Don
