-   -   DC/VA/MD area... Does anyone have a motorized trailer mover? (https://www.offshoreonly.com/forums/general-boating-discussion/115172-dc-va-md-area-does-anyone-have-motorized-trailer-mover.html)
Sydwayz 10-26-2005 11:29 AM
I need to use/borrow/rent a powered trailer mover that is very compact; similar to:
http://www.powercaster.com/
http://www.compcor.com/trailertug.html
http://www.powermoverinc.net/
I am trying to put my boat inside a friend's barn for the winter, but I have to use something like this to manuever it in beside his boat.
I can rent something like this for a day for about $150 bucks, but its still probably going to be too big.
http://www.pioneerrentalsinc.com/ima...ingobucket.bmp
Little help? Thanks in advance.
Dave M 10-27-2005 10:14 AM
Re: DC/VA/MD area... Does anyone have a motorized trailer mover?
This might be a stretch but what about those things people put under the wheels of cars to move them around? Put one under the tongue. If you are on a level surface a few people could push. Or, use a come-along.
Sydwayz 10-27-2005 10:44 AM
Thought about that too, as the boat has to be pulled into its parking space. Its a 37' AT weighing around 11,500 lbs. as it sits now. Floor is concrete, but its a matter of threading a needle, and butting the coupler within a few feet of a corner.
Shah Mat 10-27-2005 10:58 AM
Do they have a tractor? My Dad has a trailer ball attachment for his bucket on the front of a Kabota tractor. Works like a charm for moving trailers around.
jollyroger 10-27-2005 11:03 AM
You might want to try this. A friend of mine mounted a Class IV hitch to the front of his truck (Chevy 2500). He uses it to move his Fountain 10 Meter into some tight winter parking. It makes moving boats around in tight spots pretty easy.
Woodsy
BAJA342 10-27-2005 11:39 AM
Brian,
Don't forget that what ever you use, you'll need it to get back out also. Besure to have avail. come spring.
Frank
88Fountain 10-27-2005 11:43 AM
I have a 4x4 Kubota tractor with a front loader with bucket teeth. I use mine to move mine around. I am in Haymarket, where are you located?
Sydwayz 10-27-2005 11:45 AM
Thanks everyone. Unfortunately, a front hitch won't work, but I would not mind having one someday. Once I snag a dually, I am sure I will install one.
I really need a powered device that is tiny for this task.
Sydwayz 10-27-2005 11:49 AM
88Fountain, I am pretty sure we have crossed paths before. You were restoring your boat in a barn right? I bought some property off the side of Bull Run Mountain a couple years ago, and since sold it. I am trying to put the boat in storage in Culpeper at a good friend's place. I am currently in Woodbridge, but moving further south hopefully sooner than later.
Danny Usnik 10-27-2005 11:58 AM
Check some local riggers machinery movers.. they use skates that will handle plenty of weight....
you can put them under your tires at whatever angle you need and keep changing the angle until you thread the needle.
Just a thought..............good luck.
