Re: What kind of high perf drive do you run
FX10
How does the price of those compare to XR's? About the same or a little more??? :rolleyes: |
SSM#4 with 850hp
Originally Posted by Quiet Storm
FX10
Originally Posted by FX10
Want tough?? These SCS Sage #8 drives can handle 1500hp. Like an Arneson to the tenth. Drive has lift + - 4". And only weights 350 !! A # 6 drive weighs 520 lbs.
Here's some pricing I have found:
Stock XR's from Bam marine 7695.00 ea Imco sc extreme 9800.00 ea plus options B-Max 12,500 ea or takeoffs at 8900.00ea Teague Platinum 8900.00 ea Max Machine Worx Nothing is cheap except the older XR's for 6895.00 ea Older XR upper only is 3695.00 ea |
1 Attachment(s)
Max Machine Worx Kevlar Top Gun with 850+ per side , blew starboard twice this summer, at 45 hrs then at 9 hrs. and that was being very very careful with the sticks.
We are taking some boost out next summer. I run #6 dry sumps on my Cat with 850s no issues in 120hrs! I have come to the conclusion in speaking with several friends with similar rigs that beefed up Bravos are only good for 700 hp or so , and that they all use similar components. Good Luck! |
Ttt
IMCO Exterem SC' here... blew two uppers this year (both port and stbd drive). First was at 20 hrs, second at 25-30 hrs, 720 hp in a 10,500lb boat running conservatively.
I'd go with the MaxMachine or Bmax if you wanted a bravo type drive. Problem is, all of them, except for the BMax upper use the merc gears. Other than the top cap, the XR is just as good as any other drive with the exception of the shafting, if you get XR's have them set up and get an aftermarket top cap to tie it all togeher. Bigger is better when it comes to torque. I learned my lesson the hardway and I don't have as much power as some of the others who have posted here. |
[QUOTE=FX10]Want tough?? These SCS Sage #8 drives can handle 1500hp. Like an Arneson to the tenth. Drive has lift + - 4". And only weights 350 !! A # 6 drive weighs 520 lbs.[/QUOTE
Great package but #6s will still carry a higher resale value on your investment.Maybe not enough press going around about scs.Every time they invent something new the rules change in racing so no one can race it.I think the mercury gods control the market. |
[QUOTE=HotPursuit]
I think the mercury
| All times are GMT -5. The time now is 04:28 PM. |
