Worlds QUIETEST 36 Nor-Tech!!!!!!!!! >
Old 12-15-2006 | 06:13 PM
  #61
ACTIVESHACK's Avatar
Default Re: Worlds QUIETEST 36 Nor-Tech!!!!!!!!!
Originally Posted by salesmanship
I don't think anybody can take credit for underwater exhaust being "NEW" technology. What we did was come up with a new and unique way to make it work without any of the negatives.
TS
I read a book last winter titled "The Blockade Runners of the Confederacy". There was a chapter about the Rebels inventing underwater exhaust on the steam engines to escape detection from the Union blockade ships. They had valves to switch to shift from the smokestack to underwater(possibly the first silent choice) but only used it when necessary because of the back pressure on the engine. Just a little history 101 tonight.
ACTIVESHACK is offline
Old 12-15-2006 | 06:14 PM
  #62
just a question ,how about sitting in open water can waves and water get pushed up into cyls thru open exhaust valves,otherwise sounds cool
dmaxx3500 is offline
Old 12-15-2006 | 07:25 PM
  #63
Brad Zastrow's Avatar
No more chance than any other exhaust that exits the drive or below the water line like almost all pleasure sterndrives.
Brad Zastrow is offline
Old 12-18-2006 | 08:34 AM
  #64
Originally Posted by FeverMike
Terry, have you tried this exhaust set up on a V-Hull with a Bravo style drive yet?
We have on the 50 V with 6's. On the Bravo we use transom mounted turn downs to put it under the water at idle only.
salesmanship is offline
Old 12-18-2006 | 08:40 AM
  #65
cougarman's Avatar
Terry,
What power was in the 50" V-Bottom? Did you notice (Anything) Different from the cat to the V-Bottom?
Also I for one like the sound of two into one exhaust very unique very different. But if memory servers me seems the biggest reason people have gotten away from that is the ( Y )
pipe cracking at the welds with heat expansion. I don't see that as a problem with your rubber connectors.
But in the past year or two the 41' Apache WarHawk was restored and he had two into one exhaust and was hoping to go with it again. Can't remember the details, but if memory serves's me ( I Think ) Teague wouldn't warranty the engines in the configuration. Or felt the would make the proper power, they are Teauge 900's.................
So is Mecury concerened with that?
Also are you increasing you exit pipe, like going from two 4" pipes into on 5" or 6" pipe to keep the flow?
Cougarman
cougarman is offline
Old 12-18-2006 | 09:43 AM
  #66
The 50 V had trip 850's
The collector pipe is 6" i.d.
Mercury loves the system and is pushing for everyone to do something like this.
Old 12-18-2006 | 11:07 AM
  #67
cougarman's Avatar
Sounds thought out !!
Cougarman
Old 12-18-2006 | 11:47 AM
  #68
It would be great to have this available for the aftermarket, but I suppose that it's a custom item or for an OEM who can order multiple sets.
Do you think the NorTech cat setup might work on other cats? I'd like to have it.
Due
Dueclaws is offline
Old 12-18-2006 | 06:51 PM
  #69
I have custom turndowns on my 50v with triple 6's, had to custom make them so they would fit between drives, etc, work awesome, would work on other cats if you have enough room to drop exhaust behind motor thru transom, the nortech cats have a ton of room in the engine compartment. I'm sure cmi will build you a custom set of tailpipes for the under water exhaust, but open your wallet.
Buddy OO is offline
Old 12-19-2006 | 07:14 AM
  #70
rv
wiggler,
Not so sure CMI is anymore expensive than others on downturns. What are you getting for a pair of your custom downturns? CMI maybe cheaper than you think.
Rick
rv is offline
