-   -   Bravo I upgrade question (https://www.offshoreonly.com/forums/general-boating-discussion/118223-bravo-i-upgrade-question.html)
nauti-buoy 12-11-2005 01:56 PM
I am going to soon be going thru and replacing the gears and bearings in my Bravo I (1988 drive that has never been worked on as far as I can find out) drive and was wondering if I can replace the gears with the new version Bravo XR gears with out any machining of my old drive? Or is there any difference in the replacement Bravo I drive and the new XR drive grears?
The reason for the rebuild is i am adding more horsepower.
I am just trying to stay away from the expence of a new drive such as a max machine worx drive.
Thanks in advance for you help!
RedDog382 12-11-2005 02:15 PM
Re: Bravo I upgrade question
The lower case was re-designed after 1988. Sometime around '91. Better hydrodynamics and also a system to circulate the gearlube. If you are over 70 m.p.h. you may benefit from the newer syle lower case.
HighPriority 12-11-2005 05:21 PM
The XR gears will not fit the Bravo 1 drive at all. The housing is completey different.
nauti-buoy 12-11-2005 05:56 PM
I was afraid of that. thanks anyway.
Edward R. Cozzi 12-11-2005 06:05 PM
There have been two upgrades to the gear sets since your drive was manufactured. A rebuild will automatically fix this situation.
