Props in or out on a trip
#31
Originally Posted by bjlesl
It's not a Larry Smith it's just a standard Wellcraft. I have Larry's contact numbers thankyou. I don't live in Detroit I'm in N.Carolina. Has for the measurements rpm's currently 5200-5300 I want to turn 6000 gear ratio is 1.5 the toe is set at .062" per side in I have tried it out no noticable change. Set back, I'm not at home I'm in Daytona testing soit & the rest of the measurements I don't have with me. With a trip does props out help with transom lift?
Also, turning out should lift the transom some, and so will a 5 blade but may not give bow lift which could scrub some speed. A lot of times though the older flat bottom boats need bow lift so Larry Smith may be able to help out with prop selection the best.
Good luck!
#32
Thanks Panther. Also the answer is starting my 16th. year traveling full time it gets very old moreso when you have a child & an offshore boat you never see.
