Like Tree0Likes
Audio question - running 8 speakers off a 2 channel amp
Old 01-09-2006, 01:33 AM
Trade Score: (1)
onesickpantera's Avatar
My Boats: 1999 Pantera 24 Sport
Default Audio question - running 8 speakers off a 2 channel amp
I have a pretty good understanding about ohm load(I think) but I want to make sure I am on the right track.
If I wire 4 speakers to each side of a 2-channel amp, and wire 2 in parallel and two in series on each side, then my load should be 4 ohms, right?
And, will doing it this way put the same amount of power to each speaker? Or will the speakers wired in series have less power going to them than the speakers wired in series?
onesickpantera is offline
Old 01-09-2006, 02:02 AM
BigSilverCat's Avatar
My Boats: 2016 50' Skater Catamaran , 2003 41' Apache Cat, 2003 36' Cigarette Gladiator
Default Re: Audio question - running 8 speakers off a 2 channel amp
no they do not get the same power, and it depends on the ohm rating of the speakers if you end up at 4 ohms, it is late and I am not going to look up the formula but I think it is (r1 x r2) / (r1 + r2) = ohm, for parallel where r1 and r2 are speaker loads ie. 4 ohms and series is r1+r2+r3 .....=ohm, as far as you want to go .
BigSilverCat is offline
Old 01-09-2006, 02:10 AM
Anarchy Powerboats's Avatar
My Boats: www.anarchypowerboats.com
I have a diagram I can fax you with a 4 ohm load wiring for 4 ea 4 ohm speakers. Send me a PM.
Anarchy Powerboats is offline
Old 01-09-2006, 02:11 AM
what you said for two in parallel and two in series we will call the speakers 1,2,3,4 and assssssume they are 4 ohm. you would take two in parallel and and it would be (4 x 4) / (4 + 4) = (16) / (8) = 2 ohms then take the 3 and 4 speaker in series 4+4 = 8 then consider speakers 1 and 2 as one speaker that is 2 ohms and speakers 3 and 4 as another speaker with 8 ohms and you will be paralleling them (2 x 8) / (2 + 8) = (16) / (10) = 1.6 ohms I dont know If I did that right but it is late.
Old 01-09-2006, 02:13 AM
for the speakers to get the same power and not be two low you need to series two speakers, then series the other two speakers and then parallel both sets of them together. and the parallel of 4 4 ohm speakers is 1 ohm which would be to low
Old 01-09-2006, 02:15 AM
when you are going to do it you can call me if you have any questions.
tyson
417-437-0665
Old 01-09-2006, 09:20 AM
Trade Score: (1)
Quote:
That makes sense. Just when I thought I had this stuff figured out! So, series two speakers together to make 2 8 ohm load "speakers" out of the 4. Then parallel those 2 "speakers" to get the 4 ohm load.
Old 01-09-2006, 09:49 AM
Charter Member #232
Audiofn's Avatar
My Boats: 1979 Formula 302, 99 Formula 353, 81 Donzi 18 2+3 with 454
Then put your ohm meter on the leads that you are going to put into the amp just to make sure you did it correctly. Big Yellow hinted to speakers not having exactly 4 ohms because no speaker will give you a real 4 ohms. Ussually you will see like 3.6 or so (tired myself and can not pull the info out of my puny little brain.) So you can actually ballance the loads out if one or more speakers are a little off.
Jon
Put your best foot forward!
Audiofn is offline
Old 01-09-2006, 10:27 AM
Trade Score: (1)
Quote:
Jon
Thanks guys, I think I am figuring it out now. And in doing so, it seems like getting the amp as close to the 2 ohms is basically free power. The only problem I have is the formulas, they make sense until I add more speakers.
If you have 2 4ohm speaker wire in parallel then the load is 2ohms
(4x4)/(4+4) = 16/8 = 2 ohms
Now, if I do what big yellow cat says I basically have made 2 "8 ohm speakers" and when wired in parallel gives me 4 ohms
(8x8)/(8+8) = 64/16 = 4 ohms
Now, let's say hypethetically I add two more speakers to each channel and wired those two in series as well for a total of 3 "8 ohm speakers". Now I wire all three in parallel. My brain is telling me 8 ohm load/3 = 2.67 ohm total load. But, using the formula I get a WAY different answer.
(8x8x8)/(8+8+8) = 512/24 = 21.33 ohms
Which one is right? It has to be 2.67 ohms cause my brain says that's logical! LOL
I know it's Monday and I am slow but I usually get this stuff right away! But I am confused!
Old 01-09-2006, 10:32 AM
the formula is for 2 loads not 3. you have to do 2 loads at a time then you can combine them.
BillR
01-25-2008 10:20 AM
BillR
Cigarette
3
12-05-2006 08:08 AM
