What does it take to run your props inward?? >
Old 01-10-2006 | 06:48 AM
GOODT's Avatar
Default Re: What does it take to run your props inward??
spinning in in most cases will pick up a little speed but will also make most boats handle differently alot of times it will cause the boat to chime walk especially velocity, as for # 3s swap the drives for bravos you need to change the hook up at the shifter......
GOODT is offline
Old 01-10-2006 | 07:04 AM
Croozin2's Avatar
Originally Posted by Underdog88
hmmmm.... may be worth looking bad at the dock for that
If the dock's not crowded it's OK. Add a couple dozen boats and a little cross wind and things get exciting really fast!!
Croozin2 is offline
Old 01-10-2006 | 07:06 AM
GLH's Avatar
GLH
Originally Posted by OldSchool
...I didn't get enough seat time to get used to it.
No way work got in the way.
GLH is offline
Old 01-10-2006 | 09:08 AM
Underdog88's Avatar
Veteran: Navy
Great info.
So my Bravos w/IMCO lowers, I only need to swap shift cables and props? Thanks!
Underdog88 is offline
Old 01-10-2006 | 10:02 AM
Docking with inbound only takes seat time and paying attention to what you are doing. No sweat with my cat.
shawn is offline
Old 01-10-2006 | 11:13 AM
OldSchool's Avatar
I'm no expert, but doesn't the drives being farther apart on a cat make it easier?
OldSchool is offline
Old 01-10-2006 | 12:14 PM
thisistank's Avatar
Well that pretty much settles that...I wont be swaping my drives around!
thisistank is offline
Old 01-10-2006 | 12:31 PM
BajaRunner's Avatar
Ive got a VERY dumb question, If your spinning in, your LH prop is on the starboard side correct?
BajaRunner is offline
Old 01-10-2006 | 12:36 PM
birdog's Avatar
It's worth trying..Mine spin "In" I just dock like a single engine boat & use the inboard {dockside} engine when i am close
Craig..I think i have a guy interested in your big props
birdog is offline
Old 01-10-2006 | 01:06 PM
thisistank's Avatar
LH meaning left hand prop? if yes then yes. If you're spinning out right now and you change it to spinning in your original left hand prop (spinning out/ originally on the port side) would be on your starboard side when spinning in. makes sense?
