Ouch! How common is this failure >
Old 01-24-2006 | 05:02 PM
  #51
Superboat Guy's Avatar
Default Re: Ouch! How common is this failure
Is anyone here the new owner??
Superboat Guy is offline
Old 01-24-2006 | 05:57 PM
  #52
JROMY's Avatar
Anyone know what happened to the trailer?
JROMY is offline
Old 01-24-2006 | 07:12 PM
  #53
Cignificant's Avatar
Originally Posted by lightspeed
I Put A Bid Of 12500.00 In And Didnot Here Anything ???
Beat me - I bid $5K...
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 01-24-2006 | 07:23 PM
  #54
LarryD
that gimble ring failure is very common on race boats seems to come from hard turns and rough water can cause the pins to wear the ring ( we check for play every time out of water) it doesn't" just happen" unless you hit something or violent spin out , I have seen that six times this year alone in 8 races , we did it in corpus cristi looks like helmet failed which took out the gimble ring bent steering rams , bent trim rams, broke upper drive housing , exploded the U-joints , bent imput shaft, etc.
Larry SVL # 5 wild ride
Old 01-24-2006 | 07:31 PM
  #55
Beat me too..Put $5000
cowisl is offline
Old 01-24-2006 | 10:05 PM
  #56
satisfactionII's Avatar
Originally Posted by damdonzi
Crazy site! Who would buy this Black Thunder?? What possible value could there be in this heap of junk???
http://www.cooperss.com/assetdetail....2625899c0d4f8d
Definitely a black boat.
satisfactionII is offline
Old 01-25-2006 | 08:01 AM
  #57
i went and saw the boat it was my boat two years ago put a bid also 12500 you bid should of got it. i talked to a guy in texas that was hot for it after i told him the shape of it so who knows bruce
JERSEY DEVIL is offline
Old 01-25-2006 | 08:42 AM
  #58
Python82's Avatar
I didn't want it that bad. I only bid $6001. Thanks for the info the other day.
Python82 is offline
Old 03-26-2008 | 06:48 AM
  #59
Default Is This The Same Boat?
http://cgi.ebay.com/ebaymotors/33-P...tem190207776943
bbpowersports is offline
Old 03-26-2008 | 11:36 AM
  #60
Nightlife1970's Avatar
Yes it's the same boat. Get a survey if you are intrested in it!
I asked the seller if it had sank. They would not answer the question. All they said was it was the cleanest Powerplay out there and they had over 70K into it. Looks like it has the same motors in it though.
Nightlife1970 is offline
mpally
Drives and Lower Units
0
06-01-2008 07:28 PM
gerritm
05-16-2008 07:53 AM
Von Bongo
07-29-2003 04:33 PM
mr_velocity
01-22-2003 11:30 AM
SYNERGYN
10-02-2002 10:25 AM
