Engine Opinions
Originally Posted by chrisf
CMG,
Do you flush the heat exchanger every so often if you boat in salt water?
How does that work on a trailerable boat. I am familiar with big boats that have seacocks to heat exchangers. Does the intake come through the drive or is there a seperate seacock in the hull for the closed cooling.
For 454/502 Mags, do standard ear muffs work, or is there a seperate intake for flushing on these engines
Forgive my ignorance, it just seems to me that my current 5L V8 is @ 1/2 the horspower, so the bigger engines seem to need more flow than the stern drive will allow.
Educate me!
Chris
Educate me!
Chris
Chris G.
Chris G.
IMO, you will always be better off buying a fresh water motor than one run in salt. With that said, I always thought overall the 454 mag was a great engine. Again IMO, if you go with the newer 496, I think the HO is worth the few extra dollars.
It is not a big deal to flush the old 454/502 blocks. Muffs work, but make sure you run long enough that the thermostat is open so you get the circulation you need.
Originally Posted by ANDREW REALTOR
SORRY THERE WERE 4 CHOICES THE 496'S ARE FRESH 454&502 ARE NOT?
I was going to chime in that the 525s would be my first choice of closed cooling.
Splitdecision271
Do It Yourself, Boating on a Budget
10
07-21-2008 12:32 AM
2 Trick Rick
General Racing Discussion
8
10-14-2006 04:47 AM
Shah Mat
03-07-2006 05:36 AM
