-   -   Vinyl graphic removing (https://www.offshoreonly.com/forums/general-boating-discussion/121129-vinyl-graphic-removing.html)
thedonz 01-23-2006 04:39 PM
I just got my new boat and i want to remove the vinyl off of it. i was told by the guy i bought that the vinyl has been on it for like 2years. my question to yall is what can i use to remove it and when i remove it if there's a color difference from where the vinyle was what can i use to give it the shine that the whole boat has? thanks in advance
jr mike
McGary911 01-23-2006 04:49 PM
Re: Vinyl graphic removing
These supposedly work great:
Ok, that link wont work, just goto www.3m.com and so a search on "Stripe Off Wheel"
Some bigger ones, search for "Scotch-Brite™ Large Area Stripe Removal Disc"
masher44 01-23-2006 04:51 PM
Just removed mine from the side of the boat.... I used a heat gun and peeled it off and then rubbed with WD-40 and a plastic scraper (actually an old credit card) to get the adhesive off. I left the deck graphics on because I was afraid there would be too much fading around it but the sides came out nice....
It is MUCH easier with two people and 4 hands tugging on the vinyl
Clay Washington 01-23-2006 04:53 PM
Originally Posted by thedonz
I just got my new boat...
What did you get? :cool:
Dave M 01-23-2006 05:11 PM
I used GOO-GONE. As mentioned, WD-40 helps too. I can still see where the graphics were. I don't think it is real noticable, maybe it's just that I know it's there.
Jigsaw89 01-23-2006 06:04 PM
I've had excellent results with a heat gun and an old credit card for scraping the vinyl off. Brake cleaner will easily get rid of the sticker residue. Be sure to compound and wax liberally once everything has been removed.
Dan
Catagory5 01-23-2006 06:20 PM
I have had excellant sucess with these.
http://solutions.3m.com/wps/portal/!ut/p/kcxml/04_Sj9SPykssy0xPLMnMz0vM0Q9KzYsPDdaP0I8yizeIdwm2BK kAMR09DfUj0cQs3TGEjE0xhBwRIr4e-bmpQPFIc6CAoYm3oX5UTmp6YnKlfrC-t36AfkFGjpubm4W3o6OiIgBSwGPn/delta/base64xml/L0lJSk03dWlDU1EhIS9JRGpBQU15QUJFUkVSRUlnLzRGR2dkWW 5LSjBGUm9YZmcvN18wXzE0SzE!?PC_7_0_14K1_root=GST1T4 S9TCgv&PC_7_0_14K1_output=html&PC_7_0_14K1_gvel=4G V2DMPHQWgl&PC_7_0_14K1_vroot=GSLPLPKL4Xge&PC_7_0_1 4K1_node=NVJCZRM3ZPbe&PC_7_0_14K1_theme=en_US_spec ialtyvehicles_portal&PC_7_0_14K1_command=AbcPageHa ndler
Damn thats one long link. Anyway, it's a 3M STRIPE OFF WHEEL. After you remove the striping the area under may be slightly raised and will need to be sanded. Chances are you will have to cut back the entire side or deck or where ever the graphics were to get to the origional gel color and then buff it out. You can do it wet or dry depending on which system you use and what your preferance is. Gelcoat only!!!! If your boat is painted disreguard this post.
TeamTaboo 01-23-2006 06:24 PM
Do not use brake cleaner it will remove the paint also
Jigsaw89 01-23-2006 06:25 PM
Jim,
I just sent you a pm about repowering.
Thanks,
Dan
GOODT 01-23-2006 06:28 PM
heres what I use but with a different wheel made to remove pin stripes
http://buy1.snapon.com/catalog/item....e=snapon-store
but still think heat gun works best!!!!!!!
