BIG NEWS!!!!!! Whipple 5.0 liter to replace QuadRotor!!!!!
i have a 3.3 carb unit now how much for the blower and top plate for your intercooler thanks look great glade to see you back going strong
Originally Posted by knot-right
This is great !
Dustin do you have two instock to replace my mooney 10-71,s?
I was planning a PSI 206B with your double intercooler.
Change my mind.
I am shooting for 1200 on pump gas
557 with big chiefs and Dominators
If you have them I will call you.
Thank you
Gerry
Change my mind.
I am shooting for 1200 on pump gas557 with big chiefs and Dominators
Thank you
Gerry
We'll have them in about 4 weeks, no problem supplying air for 1200 on pump gas. You can still bolt it to our double intercooler or single billet, or use our smaller one, flipped upside down, only adds 1.5".
Thanks,
Dustin
1)OK My mooney snouts will bolt to the front of these?
2) the base will slide down on my richard lee intercooler
studs?
3)The top carb flange is standard side saddle or regular?
4) how much?
Thanks again
Gerry
studs?
4) how much?
Thanks again
Gerry
YEAH What he said
Direct replacement for the XX-71,s.
It can then fit Littlefield, Mooneyham, Indy, etc. intake manifolds with no machining. Of course, it also fits our intake manifold and intercoolers.
If you have a 3.3 now, this is a huge jump in airflow so pulley sizing will more than double!
Dustin
studs?
4) how much?
Thanks again
Gerry
studs?
4) how much?
Thanks again
Gerry
1. Yes
2. Yes
3. It has the standard 6-bolt pattern so you can use any adapter you want on top.
Thanks,
Dustin
Originally Posted by Whipple Charged
Honestly, we've been going so fast, I haven't had time to break the price down all the way. It's going to be more than a roots, but less than our quad. The SC, drive, pulley, bypass will run somewhere around $4500-$6000 but don't shoot me if it changes
Dustin
Dustin
Dustin[/QUOTE]
Wow
That would make it even more efficient and might not even have to run the inner cooler .It might be a little much on my 500efi
Rob
Dustin[/QUOTE]
Wow
Rob
