Black transom
Old 02-26-2006 | 11:04 PM
Default Re: Black transom
Sure was running nice as you guys pulled away on the way back
Quality Time is offline
Old 02-27-2006 | 12:21 AM
Strip Poker 388's Avatar
Rob
Mine use to do it when I idled a lot . I heard the 500efi are a little rich at idle .Also heard the high octane. I always ran 93 in it and i put A MSD box on it and it helped ..
Ray @ Raylar your saying they changed the mix/blend recently ????
Rob
Strip Poker 388 is offline
Old 02-27-2006 | 07:00 AM
CAP071's Avatar
87 and an msd box cleaned mine up like a champ. if you idle around lots it's gonna happen.
CAP071 is offline
Old 02-27-2006 | 08:02 AM
Rob
I think he might be refering to the ethanol that is now being blended with most pump fuels.
Magic Medicine is offline
Old 02-27-2006 | 08:17 AM
DJD
How much oil does it "burn"? We had a problem with a simple pcv valve on our F2 race boat. Transom was BLACK after a test run right before the race. It didn't do it unless we were running hard.
DJD is offline
Old 02-27-2006 | 11:00 AM
Semper Fi's Avatar
I would probably say that it's the fuel. California is more stringent on fuel than most states because of the air polution. Maybe the fuel mixtures/ additives have changed somewhat to be causing this?
I saw a report on consumer affairs about 4 yrs ago when they tested different fuels--87,89,91, there was prctically NO difference in the fuels from a few major brands.
There is actually a big difference in fuel quality between different fuels. They all blend their fuels differently with various additives. I only trust and use 76 or Mobil
Semper Fi is offline
Old 02-27-2006 | 11:20 AM
Gizmo's Avatar
Are we having fun, yet?
I have a pair of hp500's and am experiencing the sooting on the transom. I have been told that it is a common issue with these engines. Also been told that the A/F mixture is fattened up at idle to keep from leaning out at high RPMs. I had some relief work done to the heads and the sooting is not as bad as it used to be. Just my .02 worth.....
I run 89 octane most of the time.
Jay
Gizmo is offline
Old 02-27-2006 | 03:11 PM
ALL 500 leave sooty transoms... they r set rich at the factory... end of story...lean it out w/ a ecm reprogram
dreamer is offline
Old 02-27-2006 | 03:45 PM
From: Lakeway, TX (Austin/Lake Travis) / LOTO Gravois Arm
I had this "problem" with my 496. Was also told it is normal for this to happen. Someone suggested I add a K&N intake.
I did that. Less black, and not too lean.
In2Deep is offline
MikaylaHunterCig
6
03-03-2006 12:20 PM
ApachePete
04-11-2004 04:55 PM
N2BOATN
3
07-14-2003 03:13 PM
Audiofn
5
09-30-2002 08:51 PM
B38
21
02-25-2002 07:15 PM
