Center of Gravity on boats?? Question
OK so their are many Mfg's staggering their motors in the engine compartment to better the CG like Fountain, Cig, OL, I am sue their are others ( and getting great results)>>> OK so my question is if you replace a current set up with the new Ilmors they save you about 600lbs, wouldn't that better the CG on a regular side by side set up?? Achieve the same results if not better?? Just looking for insight and opinions
WILL :D |
Re: Center of Gravity on boats?? Question
You will be reducing the weight in the rear, but staggering sets your COG forward and lower in the boat.
It also gets your dives lower and closer together. Regardless, it would be a MAJOR job to change a standard config to staggard, so I'd take the weight reduction anyday!!! |
Stormrider,
Great point, I forgot about staggering being able to put the drives closer. However my point is by making the rear lighter that will move COG farther forward? Thus improving performance?? Just things to ponder. WILL :D |
yea, i'd agree w/ you on that.
You could always add some lead forward if the boat needed it. I think lighter would be better anyway. |
1 Attachment(s)
the less wetted surface the better. every boat is different. tough to make that call. one thing for sure a good c,g will run the boat pretty darn straight without x-cess trim,,,, like this, therefore ending up with very efficient speed.
low, inside, and pending step locations and bottom configuration avg. 70/30 split
WILL :D |
Rob :D |
| All times are GMT -5. The time now is 07:55 PM. |
