Personalized Dock Lines
Old 03-19-2006 | 03:25 PM
HiPerf2000's Avatar
Default Personalized Dock Lines
Got these in last week. Nice quality, soft docklines. 1/2" X 25'
Attached Thumbnails Personalized Dock Lines-camden-sonic-5.jpg   Personalized Dock Lines-purple-lines-001-large-.jpg   Personalized Dock Lines-purple-lines-003-large-.jpg
HiPerf2000 is offline
Old 03-19-2006 | 03:28 PM
Ms PatriYacht's Avatar
Default Re: Personalized Dock Lines
nice looking, do you mind me asking from where and how much
Ms PatriYacht is offline
Old 03-19-2006 | 03:39 PM
Spine Tingler's Avatar
Yeah, what she said
Spine Tingler is offline
Old 03-19-2006 | 03:43 PM
drypipetiger's Avatar
Looks like Top-Knot at
http://www.mooringlines.com/
drypipetiger is offline
Old 03-19-2006 | 03:52 PM
HiPerf2000's Avatar
they were $28 per line.
go them here....
http://www.myrope.com/
Old 03-19-2006 | 03:58 PM
Thanks for the info.
Old 03-20-2006 | 07:35 AM
Dog Leashes also. So now you dog can coordinate with your boat Thanks
Old 03-20-2006 | 07:43 AM
Pantera1's Avatar
Those look nice ..but when I hear floating , that means one thing POLYPROPYLENE.
Also , those are not a true splice , it looks like they just lay the rope paralel and stitch on the nylon cover
Because of its light weight, polypropylene is the only rope which floats. For this reason, it is very popular for pool markers and water sports. Poly is affected by sunlight deterioration, more so than any other synthetic or natural fiber rope, but its life can be extended by storing it away from direct sunlight. Poly begins to weaken and melt at 150°F, the lowest melting point of all synthetic ropes. It is not as strong as nylon or polyester, but 2-3 times stronger than manila. Because poly is less expensive than other fibers, it is the most popular all-purpose rope for the average consumer.
I like Nylon myself
Nylon is the strongest of all ropes in common use. When stretched it has a "memory" for returning to its original length. For this reason it is best for absorbing shock loads, as is the case when lifting or towing. Nylon lasts 4-5 times longer than natural fibers because it has good abrasion resistance and is not damaged by oil or most chemicals. Like manila, nylon has good resistance to ultraviolet deterioration from sunlight, referred to as "U.V. stability".
Pantera1 is offline
Old 03-20-2006 | 08:12 AM
Pantera1's Avatar
http://www.neropes.com/pleasure_marine/default.htm
Click on fibers
Try these Nylon double braids , youll never go back
Pantera1 is offline
R Addiction
07-05-2006 08:30 AM
Fast Forward
5
02-08-2006 08:11 AM
stevebaretta
02-16-2004 11:09 PM
Tantrum
05-29-2002 10:20 PM
