Check out my JetDock playground setup! >
Old 03-31-2006 | 07:43 AM
pkspx's Avatar
Default Check out my JetDock playground setup!
Wanted to show off the Jet Dock system. Have had it installed since 97 and love it. Jetdock actually started their first drive on boat system with the boat and used this one for testing. (like a beta version or prototype) If you log onto the www.jetdock.com site there is a video with it driving on the dock.
This past summer.
http://www.customtints.com/454/boat4.JPG
Prototype testing for jetdock. Check that setup up. Back in the day with the old Seadoo jet boat, now sold.
pkspx is offline
Old 03-31-2006 | 09:27 AM
PhantomChaos's Avatar
Default Re: Check out my JetDock playground setup!
They pretty much show the boats getting on the dock .......if your props or jet are out of the water, how do you get back off the dang thing?
PhantomChaos is offline
Old 03-31-2006 | 09:30 AM
Semper Fi's Avatar
Good point Nort. What if a strong wind comes along? Looks like the boat needs something to secure it from possibly leaning on a side
Semper Fi is offline
Old 03-31-2006 | 10:00 AM
Airpacker's Avatar
My bro in law is the Canadian distributor for Jet Dock. Its pretty slick. There are smaller( height) sections that go under the keel and plastic pipes on either side of the "groove" to stabilize the hull. Theres a winch and pulley system to back the boat off enough to get your props wet. then ya just back off. The seadoos he has just slide off with a push. They also have a submergible set up with an air pump for bigger boats. Only real problem is the black plastic will blister your feet in a hearbeat on a hot summer day.
Airpacker is offline
Old 03-31-2006 | 10:29 AM
Wobble's Avatar
SORE MEMBER
So what does a jetdock cost for a pwc? roughly.
Wobble is offline
Old 03-31-2006 | 05:35 PM
CAP071's Avatar
CAP071 is offline
Old 04-03-2006 | 09:06 AM
pkspx's Avatar
The boat jet dock systems have a pump much like the Hydro systems. There are tanks under the dock that hold air when you leave over night or sink if you want to go boating. The prop is allways in the water and your engines get water no problems.
pkspx is offline
Old 04-03-2006 | 04:43 PM
mjpcowboy's Avatar
I would not want my props and lower drive in the water all the time, i will stay with the hydro type lifts just my $.02
mjpcowboy is offline
Old 04-03-2006 | 09:23 PM
pkspx's Avatar
Once you pump up the dock raise the outdrive and you are good to go. Boat is 100% out of the water. Dave Faber of Jetdock owns a 42footer 3 engine performance boat, system works same way. His drives sit out of the water as well.
pkspx is offline
Sydwayz
2
05-15-2007 10:35 AM
pkspx
Powerquest
3
03-27-2006 08:56 AM
Flaoffshore
06-18-2004 11:11 AM
