Motorized Navigation Pole Light??
Has anyone ever seen a motorized 360 degree navigation pole light....similar to a power antenna?
Re: Motorized Navigation Pole Light??
Eddie Marine about 150 bucks. Try Trick
Unless you are real set on one, you might want a regular one. The internal connections on those don't seem to hold up well, makes the light blink a lot and sometimes just not light :evilb: Always an adventure :D
I'm seeing them more often these days on boats I survey. I believe Cablemaster is the manufacturer.
Innovative lighting makes one. New ones are LED and I have had no trouble with mine. If you turn the switch on then off then back on it will signal SOS. I really like mine and I also have a stern light mounted on the transome so it is more of an anchor light. I got mne from Eddie Marine. :drink:
http://www.eddiemarine.com/Cart/deta...&CategoryID=56 |
I have one I'll let go for $50.00. Never installed. Also have a bow nav light that is motorized.
3 Attachment(s)
Here ya go
Originally Posted by insptech
...internal connections on those don't seem to hold up well, makes the light blink a lot and sometimes just not light...
Also there is a setting that will make the light blink SOS in morse, maybe you are mistaking that setting for loose connections. I use my boat in fresh water also, so it might be a salt water enviroment issue if there are people having problems with those. |
scottc,
You have a PM. Baja Pete |
kill 2 birds with one stone! get a motorized stripper pole and put a light on top :D
| All times are GMT -5. The time now is 10:42 PM. |
