PROPS.......Is this true or not >
Old 04-25-2006 | 09:19 PM
Default PROPS.......Is this true or not
Are Bravo 1 props actual ptch what they are stamped or is there any truth to the rumor that they are 1 1/2 pitch less..for example......a Bravo 1 24-4 blade is actually a 22.5...Second...on a 253 Convincer(97)..is a Hydromotive prop better than a Bravo 1...Which has better performance..Thanks
SED70 is offline
Old 04-25-2006 | 09:25 PM
onesickpantera's Avatar
Default Re: PROPS.......Is this true or not
I've heard they are 1" less pitch than stamped.
onesickpantera is offline
Old 04-25-2006 | 10:01 PM
Assuming you mean a Hydromotive Q-IV vs. a Bravo 1. From my experience the Hydro cause alot of stern lift. On my old 24' Baja it was so much I couldn't trim past it and the prop caused bow steer. Bravo 1's are more of a a bow lifting prop. You likely have a fairly deep x-dimension, so a Bravo 1 would be my vote. Try them out and tell us how it goes. Just my $.02
Holy Smokes is offline
Old 04-25-2006 | 10:09 PM
FeverMike's Avatar
Yes if you are running for example a 24 pitch Hydro 4 blade you would need a 26 Bravo 1 to turn around the same rpm.
Hydro's are more of a stern lift prop and Bravo's are more of a bow lift prop.
FeverMike is offline
Old 04-25-2006 | 10:10 PM
Tantrum's Avatar
Bravo I's run one inch smaller that marked. A 24 would measure out at 23". Props make a huge difference in your boats performance and each hull will respond differently to a given prop. Even though a Bravo I is an excellent choice for alot a different applications you should talk to someone who has experience with your particular hull and the prop you are thinking of using.
Call Brett at BBlades, he is a sponsor here and knows the shiznitz.
Tantrum is offline
Old 04-25-2006 | 10:41 PM
The stamped pitch is the maximum pitch on any one blade. All the others are blade will be less. The 1" less pitch is a good rule of thumb.
Griff is offline
Old 04-25-2006 | 10:54 PM
HiPerf2000's Avatar
I tried every type prop on my old 253 Check. Hydro QIV RH is the best prop for that hull.
HiPerf2000 is offline
Old 04-25-2006 | 11:06 PM
racesdad's Avatar
call matt and julie at throttle-up in st pete. they will get you dailed in better than anyone
mike
peppers racing
racesdad is offline
Old 04-26-2006 | 05:35 AM
offshoredrillin's Avatar
I agree Brett is great to talk to and knowledgable..He used to work at Merc, no one better to ask then
offshoredrillin is offline
Old 04-26-2006 | 07:46 AM
Brett A worked in Mercury's prop dept for Many years. His website is www.bblades.com . If your looking to increase the performance of your boat this is a very good start.
marc
Maximus is offline
powerplaysales
Powerplay
40
02-15-2007 11:24 AM
HOTTZU98
3
05-13-2005 07:43 AM
dougB
0
05-06-2003 04:16 AM
ROUGHSTUFF
01-02-2003 12:01 PM
