My winter project on 43 Nor-Tech >
Old 05-23-2006 | 07:53 AM
rv
Default Re: My winter project on 43 Nor-Tech
Still have the 17-3/4" x 27" 5 blades. I had Brett at B-Blades tune them up to standard lab specs. I have not had a chance to get a set of data on these props yet. Once I do I will take them back to him for adjustments. He thinks they should be 17-1/4" (same as you had originally). I can tell you one thing they are much better than before for getting on plane. I bet it is at least 1-2 seconds faster. Also the rooster tail is about 4-5' higher than before at the same drive setting. Something changed!
Did you place an order yet for yours? What are your thoughts now for a engines/drives?
Thanks Mark.
Dean, yes we did have a 35 Nordic, friends of ours in Utah have it now. I guess I like that "Nor" part of the word. Yep, it has a pad.
Rick
rv is offline
Old 05-23-2006 | 08:02 AM
kswest's Avatar
WOW. I need to do that to mine.
kswest is offline
Old 05-23-2006 | 08:06 AM
wrinkleface's Avatar
Awesome job! Congratz
wrinkleface is offline
Old 05-23-2006 | 08:12 AM
Pantera1's Avatar
Originally Posted by rv
We got a 43 Nor-Tech late last year and decided to freshen the transom area some. The engines, tailstocks and all items on the transom were removed. The extension boxes remained (dam 5200 won the battle). Everything painted was bead blasted and painted. Drives completely gone through (all new bearings, seals, u-joints and 1 gear set). Marine Drives Inc in Fl did them and the paint finish is better than new, he does great work. Redesigned mounting system for steering bracket and changed mufflers out. Every piece of stainless was polished and some of it was sanded then polished, including every nut/bolt. It was a much longer process than I expected but now I know the condition is top notch and will stay this way. I attached some pictures so you can see the changes.
Rick
Wow that does look great ..that must have taken a long time considering you polished your nuts too ..
Pantera1 is offline
Old 05-23-2006 | 08:35 AM
Dean Ferry's Avatar
Veteran: Air Force
Yes you do! Here is the Mercruiser P/N for your LWP Flush attachment; 91-84996T1. Is that the number you found?
K, what are your plans for Memorial day weekend? Are you guys still going down to WPB?
Dean
Dean Ferry is offline
Old 05-23-2006 | 08:36 AM
Back4More is offline
Old 05-23-2006 | 08:37 AM
nice job!
customryder is offline
Dean Ferry's Avatar
Veteran: Air Force
Thanks Mark.
Rick
Rick,
Cool, I think you made an AWESOME "Nor" upgrade!!
Dean
Old 05-23-2006 | 10:22 AM
Brad Zastrow's Avatar
Wait till everyone looks at the boat in person. WOW! The paint glows and the stainless is mirror finished. Looks real sharp.
Brad Zastrow is offline
Old 05-23-2006 | 12:40 PM
Nordicflame's Avatar
Originally Posted by Dean Ferry
Rick,
Dean
Yes and we were the lucky beneficiaries of that move
The Flame was kept in the same manner. Brings a new meaning to better than new
Rick, maybe we can keep the sequence going and I'll be changing to a Nor*** when you get tired of this one
(I'd have to move to a place with bigger lakes though )
As expected, it looks great Rick!!
Dave
Nordicflame is offline
