twin engine docking tips?
Something else that works is many will ask when the drives are straight. while on the trailer position the drives straight. look at your steering wheel and note the position, then turn it hard port and count the turns, same then to SB, counting, generaly speaking its 4-6 turns lock to lock, center should be straight drives. Use your wheel as a guide, if there is a fast current, you can tell by lookiing at your wheel where the drives are. I repostioned my wheel so when running straight the the posts points straight down.
Originally Posted by 26sonic
just got my first twin engine boat after having 3 single engine boats , any tips on docking ? heard twins is easier than single to dock ?
Seriously...plan a day for docking, get your bumpers out and just dock over and over (when no one is around). After doing it 25 times you will know what method works best.
I remember how stressful docking could be, I practiced in the rain and on a very windy day, with a strong current. I did it over and over and docked in all spaces that were open. I remember pretending that boats were parked on both sides and I had to get in one of the inner spots, it really helped. I'll probably do the same thing with every boat I buy in the future. Good luck with your new boat.
Oh, one more pointer...don't hesitate to start over if your not approaching the dock the way you intended.
Originally Posted by The Menace
Hydraulic steering is an exception. The wheel will not return to the same position.
Back when I was a Coasite we used to take a large Norwegian style fender and attach it to an anchor line. Find an uncrowded spot with plenty of good water around, drop the fender/anchor rig with just enough line for the anchor to touch bottom.
Then practice running up slowly and touch the fender to the bow,vack off and then touch port forward quater, same for midships, and aft quarter. Repeat for the other side.
Do this in different wind and current conditions and after awhile you'll be able to put the boat anywhere you want without even thinking about it. It becomes a reflex with enough practice.
Good Luck!
Good Luck!
