Changes/replacement for HP500 Ignition Control Module >
Old 06-15-2006 | 11:02 AM
Gordo's Avatar
Charter Member #94
Default Changes/replacement for HP500 Ignition Control Module
Can anyone make changes to the Merc-Racing ICM for the carbed HP500? Is there another ICM from another package (such as the 600sci?) that would have a higher rev-limiter and more timing advance?
Is it possible to buy a re-mapped version or an exchange for this ICM?
Abby-someone
Gordo is offline
Old 06-15-2006 | 11:35 AM
KCHOTBOAT's Avatar
Charter Member #737
Default Re: Changes/replacement for HP500 Ignition Control Module
Mike
I did away with the merc ICM and have a crane box on mine now. I can set the rev and advance with a screw driver.
KCHOTBOAT is offline
Old 06-15-2006 | 11:49 AM
KCHOTBOAT's Avatar
Charter Member #737
http://www.jegs.com/webapp/wcs/store...tegoryId=23607
Old 06-15-2006 | 11:55 AM
Gordo's Avatar
Charter Member #94
Thanks Rich.
Is this a simple Plug-n-Play using the original knock module, coil and distributor?
Abby-someone
Gordo is offline
Old 06-15-2006 | 01:31 PM
KCHOTBOAT's Avatar
Charter Member #737
Originally Posted by Gordo
Thanks Rich.
I am using the stock distributor and a crane coil. I don't have the knock sensor hooked up right now but believe you can hook up the stock one or there was a optional one from crane. I hope to make it out to Perry Sat. if all my parts show up tomorrow. I will be home all day tomorrow if you want to stop by and see the setup. Here is the link for my coil.
http://www.jegs.com/webapp/wcs/store...m=270-730-0892
Old 06-15-2006 | 01:33 PM
KCHOTBOAT's Avatar
Charter Member #737
Looks like they are back ordered till next month.
http://www.offshoreonly.com/forums/s...d.php?t=132478
Old 06-15-2006 | 04:42 PM
Gordo's Avatar
Charter Member #94
Story of my life...
Abby-someone
Gordo is offline
ak_boater
15
06-20-2022 02:27 PM
Pat McPherson
13
07-21-2008 09:26 AM
Inspector
2
11-05-2007 06:44 PM
Sates
1
05-13-2005 10:24 PM
FlyFast
2
10-22-2003 10:54 AM
