SmartCraft or Analog Gauges ???? >
View Poll Results: Which would you use?
SmartCraft Only
12.79%
Analog Gauges and Indicators Only
29.07%
Some of Both
58.14%
Voters: 86. You may not vote on this poll
Old 06-27-2006 | 12:34 PM
Default Re: SmartCraft or Analog Gauges ????
Some of both!
SmartCraft provides a ton of information but can be difficult paging through while on the run. That is why I went with Mechanical trim and tab indicators as well as things like oil pressure and water temperature. Like Lucky Strike says, the fuel metering is a plus. When you fill up, reset the SmartCraft and you will know exactly how much fuel you gone through until the next time you reset.
4mulafastech is offline
Old 06-27-2006 | 12:43 PM
Stormrider's Avatar
JC Performance Engines
Analogs can be read at a quick glance.
Stormrider is offline
Old 06-27-2006 | 05:19 PM
Codered's Avatar
Go with mechanical drive and tab indicators. Smartcraft drive indicators hard to see .
Codered is offline
Old 06-27-2006 | 08:03 PM
Spine Tingler's Avatar
I wanted to do a complete digital dash, but not sure about whether I can get gauge readings from a Sterling/
Spine Tingler is offline
Old 06-27-2006 | 08:32 PM
FeverMike's Avatar
I have Smart Craft on my boat and love it. The system works hand in hand perfect with Merc engine program.
FeverMike is offline
Old 06-27-2006 | 11:15 PM
JROMY's Avatar
I've got Livorsi gauges in my Powerplay with 525's which have Smartcraft capability. I am in the process of installing a Garmin 3206 chartplotter for navigation. As far as I can make out, Merc's GPS is not a chartplotter, but a basic GPS. Am I correct in this assumption? Also, is there a way besides this Merc display to monitor the Smartcraft functions?
JROMY is offline
Old 06-28-2006 | 12:24 PM
Yes. Navman, which is owned by Brunswick (same as Mercury), has chartplotters that will display SmartCraft info with the use of a SmartCraft Gateway. Go to www.navman.com for more info. I was really close to buying the Navman Tracker 5505i but couldn't find a good place to install it in my 292. Ended up getting a Garmin GPSMAP 378 (it doesn't display any SmartCraft info) but it has a NMEA output that communicates to the SC5000 display so it can tie in the waypoint information with the engine function information. In other words... say I am navigating to a waypoint 100 miles away. The SC5000 screen will tell me based on the speed and efficiency (real time) exactly how much fuel I will use to get there. It also has the compass rose screen which will highlight the exact direction to navigate to get to the waypoint. Pretty cool.
Old 06-28-2006 | 02:19 PM
JROMY's Avatar
Originally Posted by 4mulafastech
.... but it has a NMEA output that communicates to the SC5000 display so it can tie in the waypoint information with the engine function information...
4mulafastech - What is the SC5000 display?
JROMY is offline
Old 06-28-2006 | 03:28 PM
The screen in the middle of the dash below. This is the display from Mercury that shows any and all engine and vessel information and will connect to most chartplotters. It has GPS, but just for speed, not mapping.
Old 06-28-2006 | 03:54 PM
chuckbeecher
From: Anywhere from the Laguna Madre to JAX and beyond
Have SmartCraft on the Verados and they give alot of information and can do several functions at once but I do not like having to navigate the different pages..especially while zip along at higher speeds. Some old steam guages would be great for quick glance and scanning for pressures and temps.
But do love thr SmartCraft modes for fuel used , fuel burns per engine and miles traveled for present trip. The digital read out for tachs are more precise than the tach needles also.
chuckbeecher is offline
