-   -   225 Optimax Modifications??? (https://www.offshoreonly.com/forums/general-boating-discussion/134897-225-optimax-modifications.html)
Enforcer2 07-11-2006 08:43 AM
Any mods foir the 225 OPti's? Have triple engine set up looking to get 25-40 hp from each.
dirtlawyer 07-11-2006 08:49 AM
Re: 225 Optimax Modifications???
I would ask the same question on Screamandfly.com - those guys really know outboards.
I have 225 Promaxes and have posed the same question. You can change the heads, intake, etc. but it gets costly and reliability is sacrificed.
Enforcer2 07-11-2006 09:21 AM
Thanks for the reply, I'll check out Scream and Fly.
rush 07-11-2006 01:19 PM
Tell us what you find out ,I have 03 225 optimaxs.
Enforcer2 07-11-2006 04:54 PM
No info received yet, from what i've been seeing I don't think much can be done with them.
fountain1fan 07-11-2006 06:11 PM
g force technology 920 235 5442 he is one of two people i would let work on my motor. merc raceing tec for 20 + years. robbie :drink:
Pantera1 07-11-2006 06:18 PM
DO NOT modify your optimax.. Theyve had burn down problems stock.. I wouldnt go tinkering unless you are very capable
Enforcer2 07-11-2006 06:19 PM
GOODT 07-11-2006 06:49 PM
no mods that I know of and if there where I thick id be afraid to do them....the dfi system on them is Very complicated
fountain1fan 07-11-2006 07:13 PM
if any body knows what to do it will be gean a g force . :drink:
Enforcer2 07-11-2006 08:10 PM
I'll give G-Force a call tommorow. I'll let you know what he says. Thanks again. Just looking formore speed. Going to try one more set of props an see what that will do.
Pantera1 07-12-2006 09:02 AM
Lots of places to look for speed.. Setup is key , props, lose some weight somewhere, jack plates etc etc...pair of 300's :D Optis are meant to be clean and quiet
RBT 07-12-2006 09:07 AM
Yike
Ok first, G-Force is NLA, Gene is a merc racing guy....... not an Opti guy.
You cannot modify an opti...... that is it. Nobody has bothered to try.
Buy bigger motors if you are looking for a power increase.
If you have a normal 2 stroke and want more power, look to Diamond Marine, Power Performance Engineering. The rest don't add up.
RT
Enforcer2 07-12-2006 12:05 PM
Thanks guys, I got it. No mods to optimaxes. Would like to buy new power however I need three. Wait to hit lotto.
I have already rigged the boat to it's max. Big boat needs power.
It will be cheaper to put on one more 225 than to buy the new 300 optis . Quad set up was original, last owner changed it to trips.
Thanks for the advice :cool:
Tony
fountain1fan 07-12-2006 05:41 PM
rbt nla?????????
Enforcer2 07-18-2006 12:18 PM
Talked to Diamond Marine today, regs changed in 2005 and dealers are subjected to big $$$$$$$fines for EPA regs.
RBT 07-18-2006 12:58 PM
Gene works for a marina now.
At that, Gene subed out his machine work to Jim Ruck.
If you want HP from a 2 stroke, Call Diamond or Power Performance, this is like Eickert and Sterling for 2 strokes.
RT
Pantera1 07-18-2006 03:28 PM
Jay Smith is da man
