-   -   What Is The (https://www.offshoreonly.com/forums/general-boating-discussion/135269-what.html)
BY U BOY 07-15-2006 11:18 AM
What Is The
Best Way To Drain 60 Gallons Of Fuel From A 21 Scarab. I Tried To Siphon It Out But That Does Not Seem To Work. The Reason That I Am Asking Is The Fuel Has Been In The Tank For 3 Months Now With No Stabilizer Since I Was Not Expecting It To Be This Long Of A Rebuild. My Other Question Is Can I Just Drain Some Out And Replace With Aviation Fuel And How Much. Thanks Patrick
Reed Jensen 07-15-2006 12:15 PM
Re: What Is The
Burn it.... it probably isn't that bad yet. It usually takes about 1 year for gas to be bad enough that it varnishes up everything.
BY U BOY 07-15-2006 12:27 PM
Re: What Is The
I Have Been Told That This 10 Percent Ethanol Breaks Down In 2 To 4 Weeks. I Was Thinking That I Could Pull 20 Gallons Out Then Replace With Race Or Aviation Fuel Since I Am Running 10.5:1 Comp.
DirtyMoney 07-15-2006 12:37 PM
Re: What Is The
Get a cheap electric fuel pump($50) from a parts store and connect a hose to either end and siphon it out.
BY U BOY 07-15-2006 12:43 PM
Re: What Is The
I Will Give That A Try. Atleast I Can Burn It In My Truck. :d
speedygonzalez 07-15-2006 01:49 PM
Re: What Is The
I have had very good succses with an outboard hand pump, just squeese it until it flows no moving parts to maintain and no power needed.
BY U BOY 07-15-2006 02:26 PM
Re: What Is The
I HAVE AFEW OF THOSE IN THE GARAGE. I'LL JACK THE FRONT OF THE BOAT UP AND RUN A HOSE TO THE DRAIN HOLE AND INTO FOLDING FUEL CELL. THANKS
spk1 07-15-2006 02:49 PM
Re: What Is The
Go to hi/lo, oriliey, autozone, etc, ask for a small electric fuel pump, get some fuel line, (i got about 50' of it) and then hook it up to a battery and drain away. Its pretty easy, I can help you next weekend if you havent gotten to it by then, I have the pump and the hose, but unfortunately my bro is in the hospital this weekend and I have to be with him.
BY U BOY 07-15-2006 03:20 PM
Re: What Is The
I PLAN ON DOING THIS NEXT WEEKEND. JUST WANT TO GET MY DUCKS IN A ROW BEFORE I GET MY ENGINE BACK FROM THE SHOP. I HOPE YOUR BROTHER IS OK. THANKS FOR THE OFFER I MAY TAKE YOU UP ON THAT. NOT THAT I CANT DO IT ON MY OWN BUT I WOULD LIKE TO MEET SOME FELLOW OSOERS IN MY AREA THAT SHARE THE SAME PASSION AS I DO AND THROW BACK A FEW. :drink:
Re: What Is The
Spk1 Waht Rig Do You Run And Where?
spk1 07-16-2006 12:01 AM
Re: What Is The
40' excalibur hawk, I am going to run in lake conroe for a while, then clear lake as well. I work in pasadena, so I will have the hose and fuel pump with me there. Things are looking up for my brother, hell of a deal, went in to have his appendix out, and then a staple broke a week after surgery that put him in ICU,its been going on for two weeks, if he is out of the hospital by the weekend, Im there, if he isnt, U can still borrow my hose and pump, :drink:
