best type of concrete for garage floor??
building a 1700 sq ft shop for the boat and the cars........going to be pouring the floor in a week or so.......dont know much about concrete....as far as I know theres only 2 types.....regular and some suff with fibers in it to give it strength......which would be the best???
anyone right up on this that could give a quick "concrete 101???"........remember Im in the land of cold winters..... aaaaanddd.....the building inspector says he wants to see 1" styrofoam insulation under the floor minimum around the outer edges |
Re: best type of concrete for garage floor??
3000psi or higher and have it polished out while almost dry with one of those machines
6" of 5000psi with steel, put visqueen underneath, powertrowel finish
Don't forget the radiant floor tubing. It can always be connected up at a future date.
I used the fiber impregnated concrete for my sidewalks. |
then use www.ucoatit.com or a comparable paint and sealer, you can add aluminum oxide for traction and you'll never have to worry about it again....
Use steel fibers in it, www.fiberconfiber.com
PullMyTrigger:
You want to go with a 3500psi(5.5sac)mix. Grade should be 4"-5" this is plenty for your application. Because you have freeze thaw I would recommend that they use crushed limestone. Instread of Natural round stone. It should only cost you a couple bucks extra per yard.(or meter for you canadians:D) Order your concrete with residential fibermesh. Don't use wire unless you have to, or you decide to install infloor heat. As far as the styro-foam, well that stuff is a PITA. If you are going to heat the building ask you local Lumber Yard of Redi-Mix plant for a product called Insul-tarp instead of styrofoam. Is is much easier to deal with and the R-factor is little better. Plus it is cheaper than styro. If you are pouring an approach on this building make sure that it is a 4000psi(6sac) mix. Again crushed lime stone and make sure you seal it. I live in N. Michigan and winters are tough here also. Concrete really takes a beating in the winter. Make sure your contracrtor or you don't wet the chit out of the concrete prior to pouring and never spray water on top of fresh concrete to help finishing. It will lead to future problems. PM me if you need any info. Good Luck Josh |
Don't forget to cut expansion joints. Tell your contractor to use a Soff-Cut saw and fill the joints with Sika (brand name) caulk. Concrete will do two things.. get hard and crack.
Originally Posted by Perfectmix
PullMyTrigger:
1 Attachment(s)
HMMMMM..................This is being built as we speak....all concrete, with radiant heat on both floors (only wood here is in the rafters and roofing!!! Can anyone say "BUNKER" :cool: My AT will be real safe (and warm) in here.
That place looks like a firehouse! -very nice!
Thanks, Not ours yet!! 2nd floor=1700 square foot 2 bedroom apartment with a view!! This is being built on my mother in laws property by my brother in law and will house my mother in laws mother Got that? (and my AT) :D When my Mother in law retires we're buying the house til then it's a bad azz storage place for my AT.....with heated floors!!!
The issues aren't so much additives, etc. It's quality of materials & installation. First is thickness. 4.5" would be the minimum I'd pour. Mine is 6". Next is the prep. Most concrete cracks because of settling. You need to make sure your site prep is flawless. Your contractor probably wants to get in and out. You need lots of deep compaction and that takes time- especially close to the foundation. Next is material. Specify 4,000psi concrete and require certification from the supplier. Tell the contractor you need a cured sample (this indicates you'll be having it independently tested) This will help ensure you get what you bought. If you do all this, you'll have a strong, durable floor.
The downside of in-floor heat is that you have a big challenge locating ther tubes if you ever need to drill the floor to mount something- like a lift. |
More Garage info here also. http://www.garagejournal.com/forum/index.php?
A forum section on flooring in there. |
PullMyTrigger:
| All times are GMT -5. The time now is 05:11 PM. |
