Need Help About To Leave For The Lake >
Old 08-05-2006 | 08:25 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Re: Need Help About To Leave For The Lake
If there is no way that drive fluid from an Alpha enters the engine compartment of the boat (no reservoir); then how does drive fluid come out of the bilge plug hole? Did it come from there or just appear to?
Sydwayz is offline
Old 08-05-2006 | 08:30 PM
88formula223's Avatar
NO WAKE ENFORCER
no it came from there , stuck my finger in the hole and could feel it and saw it drip from there into the small puddle
after the last time I used it, it sat at work for like three days and not a drop then I put it in storage (outside) and it sat there for about 8 days with the bow up. You would think it would have just leaked out there? it was almost a 100 degrees for 5 of those days if that had and thing to do with it?
weird
88formula223 is offline
Old 08-05-2006 | 08:46 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
So, it appears as though you are leaking fluid into the bellows, and its draining down the bellows in through the transom assembly, down the inner face of transom, and out the bilge hole. It does need to be addressed. Once you are running and heat that drive oil up and you trim the drive out to run, you may push too much of your fluid into the bellows and into the bilge, and that will break the drive due to lack of lube.... worse case scenario.
Sydwayz is offline
Old 08-05-2006 | 08:53 PM
NO WAKE ENFORCER
thanks, Im going to take it out and keep a eye on it, but dont you think it was weird that it took that long to show up?
Old 08-05-2006 | 09:43 PM
How did it work out?
RandyJ is offline
Old 08-06-2006 | 03:47 AM
berns29scarab's Avatar
call me...... 1-732-684-4918
berns29scarab is offline
Old 08-07-2006 | 01:23 PM
NO WAKE ENFORCER
worked good all day yesterday took it easy on it, took it to the shop today. He said the samething sydwayz said leaking through the bellows so hell fix it and change the impeller while hes at it, it has been running a little warm when idleing
Old 08-07-2006 | 01:51 PM
mboger's Avatar
how did your interior come out looking
mboger is offline
Old 08-07-2006 | 03:48 PM
NO WAKE ENFORCER
Good I Need To Call You Are You Going To Be Around Tomm.? Maybe I Can Come Down In The Afternoon And Get Those Bins
qshag
Fountain
34
08-13-2007 09:53 PM
JCPERF
12-17-2004 12:09 PM
jpc
08-27-2002 08:06 PM
