another LOTO shootout question >
Old 01-20-2002 | 12:26 PM
traviss's Avatar
Post another LOTO shootout question
I see the smallest class is 22'. Can someone tell me how many boats were in 22' deep vee, I/O class last year? and what speeds were they running?
Travis
traviss is offline
Old 01-20-2002 | 12:35 PM
packinair
Post
I'll run you in the 22-25 class travis
Old 01-20-2002 | 12:41 PM
traviss's Avatar
Post
is one class considered 22'to 25'?
traviss is offline
Old 01-20-2002 | 02:18 PM
mpally's Avatar
Post
It depends on what class, stock, modified, or blown. Stock was high 60's I beieve and Gordo won the modified with 81. Don't know about blown.
mpally is offline
Old 01-20-2002 | 04:00 PM
Rapid22
Post
Just how many 22 or 23' boats ran in the Shootout? It gets very rough out there. Could you actaully run a 22 ft boat wfo (cat or deep vee) in the Shootout. I have not been to a shootout since 1993 but it was rough back then.
Old 01-20-2002 | 04:18 PM
Gordo's Avatar
Charter Member #94
Post
Traviss,
That size is divided up into these classes;
22'-26' stock small block
22'-26' modified small block
22'-26' stock big block
22'-26' modified big block
22'-26' "Factory" class. (Must have mercury sealed 500HP carb or efi)
I have won;
22-26 stock big block in my Velocity @ 71mph,
22-26 modified small block in a 22' Chris Craft Stinger @ 63mph,
22-26 "Factory" class in my Active Thunder at 78mph (1999) and 81mph (2001)
26-30 single stock big block in a 29 Scarab @ 60mph.
Hope these speeds help, but there is a website that has all the winning speeds you can look at also.
I'd send you the link, but I lost it when my old computer died.
Abby-someone
Gordo is offline
Old 01-20-2002 | 04:19 PM
Gordo's Avatar
Charter Member #94
Post
By the way, those are all V bottom classes. Cats are seperate.
Abby-someone
Gordo is offline
Old 01-20-2002 | 04:22 PM
traviss's Avatar
Post
Thanks guys..
traviss is offline
Old 01-20-2002 | 05:29 PM
Post
Rapid22, the water is calm. Half the channel is for the runs and the other half is no wake for spectators.
Griff is offline
Old 01-20-2002 | 07:18 PM
Waterfoul's Avatar
Gone Fishin'
Post
You could easily run a 20' boat on that water (judging from what I saw last year). I think they should lower the minimum to 20 so TWright can run his 20' Seebold Warrior tunnel at 130 mph!!!!
Waterfoul is offline
