Belt keeps jumping off of 500 efi. >
Old 08-14-2006 | 04:17 PM
Default Belt keeps jumping off of 500 efi.
This is driveing me nutz! I checked every thing. I even replaced the belt tentioner. It jumps off when it wants to. It did it several times then it worked fine. now its doing it again. WHATTHE****!!!!!!
Velocity Tom is offline
Old 08-14-2006 | 04:51 PM
Wardey's Avatar
Default Re: Belt keeps jumping off of 500 efi.
Check the pulley allignment. We have had this problem with the race boat. Dave
Wardey is offline
Old 08-14-2006 | 05:03 PM
Everything looks ok. Its been ok 250 hrs.
Old 08-14-2006 | 05:12 PM
Strip Poker 388's Avatar
Rob
Also......I would ck the water circulater pump on the center of the engine and the water pump pullys .Maybe a bearing is going out .Ck make sure everything if tight ,brackets,Also if it chunks the belt off ya need to replace it, I would buy the Napa belts that way you can take them back get the warranted.I am turning my up to 6000-6100 at times with no problems.
Strip Poker 388 is offline
Old 08-14-2006 | 05:13 PM
Have you replaced any accessories on front or engine? If no service has been done, I would start checking each bracket holding P/S pump, Alternator, Etc. Something may have come loose and is creating a misalignment issue. I would also check the each pulley (especially crank pulley) for loose bolts also... Hope this helps.
ScarabCV is offline
Old 08-14-2006 | 06:56 PM
Thanks! I wanted to get on it tonight but we are getting one hell of a t .storm.
ROADHOG
8
05-22-2012 10:14 AM
tcm07
10-03-2008 02:00 PM
Elite Marine
20
09-12-2008 05:28 PM
Steel Outlawed
1
04-17-2006 08:29 AM
ROADHOG
2
06-15-2004 08:48 PM
