another LOTO shootout question >
Old 01-20-2002, 12:26 PM
traviss's Avatar
Post another LOTO shootout question
I see the smallest class is 22'. Can someone tell me how many boats were in 22' deep vee, I/O class last year? and what speeds were they running?
Travis
traviss is offline
Old 01-20-2002, 12:35 PM
packinair
Post
I'll run you in the 22-25 class travis
Old 01-20-2002, 12:41 PM
traviss's Avatar
Post
is one class considered 22'to 25'?
traviss is offline
Old 01-20-2002, 02:18 PM
mpally's Avatar
Post
It depends on what class, stock, modified, or blown. Stock was high 60's I beieve and Gordo won the modified with 81. Don't know about blown.
mpally is offline
Old 01-20-2002, 04:00 PM
Rapid22
Post
Just how many 22 or 23' boats ran in the Shootout? It gets very rough out there. Could you actaully run a 22 ft boat wfo (cat or deep vee) in the Shootout. I have not been to a shootout since 1993 but it was rough back then.
Old 01-20-2002, 04:18 PM
Charter Member #94
Gordo's Avatar
Post
Traviss,
That size is divided up into these classes;
22'-26' stock small block
22'-26' modified small block
22'-26' stock big block
22'-26' modified big block
22'-26' "Factory" class. (Must have mercury sealed 500HP carb or efi)
I have won;
22-26 stock big block in my Velocity @ 71mph,
22-26 modified small block in a 22' Chris Craft Stinger @ 63mph,
22-26 "Factory" class in my Active Thunder at 78mph (1999) and 81mph (2001)
26-30 single stock big block in a 29 Scarab @ 60mph.
Hope these speeds help, but there is a website that has all the winning speeds you can look at also.
I'd send you the link, but I lost it when my old computer died.
Abby-someone
Gordo is offline
Old 01-20-2002, 04:19 PM
Charter Member #94
Gordo's Avatar
Post
By the way, those are all V bottom classes. Cats are seperate.
Abby-someone
Gordo is offline
Old 01-20-2002, 04:22 PM
traviss's Avatar
Post
Thanks guys..
traviss is offline
Old 01-20-2002, 05:29 PM
Received 1,821 Likes on 907 Posts
Post
Rapid22, the water is calm. Half the channel is for the runs and the other half is no wake for spectators.
Griff is offline
Old 01-20-2002, 07:18 PM
Gone Fishin'
Waterfoul's Avatar
Post
You could easily run a 20' boat on that water (judging from what I saw last year). I think they should lower the minimum to 20 so TWright can run his 20' Seebold Warrior tunnel at 130 mph!!!!
Waterfoul is offline
Quick Reply: another LOTO shootout question
