GPS in dash, any ideas?
Old 02-06-2002 | 11:36 AM
Brad Zastrow's Avatar
Post
I replace my Gaffrig gauge with the new GPS analog Gaffrig. Looks exactly the same as the liquid filled speedo and has recall! Very easy to install just need a pull power line from the ign wire in the dash. Never will I go back to pickups again!
Brad Zastrow is offline
Old 02-06-2002 | 02:39 PM
Uncle Toys
Post
Eliminator told me about $500 and up.
Old 02-06-2002 | 03:14 PM
Airpacker's Avatar
Post
hey U.C. just put a sticker over your old speedo that says 100mph
Airpacker is offline
Old 02-06-2002 | 03:33 PM
Wally's Avatar
Were doomed!
Post
Originally posted by gassticks:
<STRONG>Quick question? What do these run ,money wise??</STRONG>
Retail for these units is $446 for the 3 3/4" face kit
And $486 for the bigger 5" kit.
That includes the speedo in a 80, 120, or 180MPH face and the antenna/receiver and memory recall switch.
Its also extra if you want it in white and extra if you want a different colored rim.
I can get it to you guys for a bit cheaper if anyone is interested. Just shoot me an email
And i have on eof these installed on my Mini-cat. Works cool from what ive played with it
-Wally
Wally is offline
Old 02-06-2002 | 04:09 PM
Wally's Avatar
Were doomed!
Post
Oh...and you can also buy the head unit alone if you want to hook it up with an exsisting GPS unit IF it has an output port on it!
The head units retail for $236 and $276
-Wally
Wally is offline
Old 02-06-2002 | 04:16 PM
Raypanic's Avatar
Post
The gaffrig digital one feature Speed, Tach, Volts and Compass all in one nice package. I installed one last week - Very easy. Recall is on the speed and tach. I split the tach signals with a SPDT Switch and can monitor each engine independantly. www.gaffrigperformance.com
[ 02-06-2002: Message edited by: Raypanic ]
Ray
Raypanic is offline
Old 02-06-2002 | 05:04 PM
Uncle Toys
Post
Thanks guys, appreciate the input. Just called Eliminator and told them to slap in the Garmin 168 - Mike, your the man! Although I did give airpacker's suggestion deap and meaningful consideration
Old 02-06-2002 | 05:07 PM
gslinger's Avatar
Post
Dean Ferry, I'm looking at the garmins 76 and 176map. My ? to you is the screen big enough or do you think that I should go with the 176?
gslinger is offline
Old 02-06-2002 | 05:19 PM
Cat & Mice
Post
UT, I am glad to see you finally came around. Also I should have called me, I can get Garmin direct and saved you some money. Make sure that Mike peterson from Eliminator orders the Transponder with water temp sensor. It only cost about $20 and is well worth it.
Pyle
Old 02-06-2002 | 05:22 PM
gslinger's Avatar
Post
cat&mice what kind of price can you get on garmin 76map 176map?
gslinger is offline
