-   -   GPS in dash, any ideas? (https://www.offshoreonly.com/forums/general-boating-discussion/13877-gps-dash-any-ideas.html)
packinair 02-06-2002 06:17 PM
I have the gaffrig speedo in my boat. looks great works great. not bad to install either. also you can leave it on when towing to make the tatel tale higher :D
Madcow 02-06-2002 07:50 PM
I have the Nordskog speedo hooked to a Garmin 180. The charting capability of the GPS is incredible! The only downside of the Nordskog is it is lit with 6 blue LEDs, and is blinding at nite. Otherwise the GPS fired speedo is the way to go. If you don't need a GPS, you can get a GPS reciver that will only run the speedo for a lot less money than the 168. Good luck :)
boot 02-06-2002 08:56 PM
Hey ,packin air, Are you saying your boat goes faster on the trailer then in the water ?
Wally ,Which brand are you talking about ?
I have a 180 garmin .It is great ,but it doesn't have max speed reading ! :mad: Which unit can I hook to it to give me this ?
Audiofn 02-06-2002 11:28 PM
You can take your Garmins and any other brand with a NEMA output and hook it up to your GPS speedo and the speedo will read the same as the GPS screen. The updates are the same as well.
Jon
Dean Ferry 02-07-2002 07:36 AM
gslinger,
For what I do with it, the screen on the Map76 unit is more than easy to read @ speed. I like the option of removing it from the boat @ the end of the day because my boat sits on a lift over Salt water, and salt water vapor is pretty intrusive. Good luck with your purchase.
MD
Madcow 02-07-2002 08:14 AM
Boot, the Nordskog speedo has a high speed memory recall.
Wally 02-07-2002 09:09 AM
Originally posted by boot:
<STRONG>
</STRONG>
The Gaffrig/Livorsi units. :D
boot 02-07-2002 09:36 AM
Thanks everybody ! Does anybody know if there is one that reads to 140 or 160 ? 120 is not enough and 180 is just a little much! :D Thanks .
Audiofn 02-07-2002 09:51 AM
Boot sounds to me like you need bigger motors not a slower Speedo :D :D
Uncle Toys 02-07-2002 10:15 AM
Oops! The Garmin 168 doesn't fit in my dash Mike :eek: I've got too many gauges thanks to Dustin (that's actually a positive - thanks Dustin!) So I went with the digital Nordskog (Eliminators recommendation). I'll call this morning and talk to Mike Peterson and see if water temp sensor is an option. Pulled out Hot Boat magazine last night and checked out your dash again and saw the Garmin. :cool: Looks cool, but god I love gauges. Guess my hand held will have to do for the mapping (if and when I need it on the water). They quoted me $600 installed. :eek: My boat has been at Eliminator now for five weeks and if I don't get it back in time for Presidents weekend I'm going to blow Micks 50 amp fuse.
p.s. Mike, how's it going up there with the winter Olympics?
