Battery advise
Old 08-26-2006 | 09:10 AM
Indy's Avatar
Member #154
Default Battery advise
I'm looking to put some new batteries in the boat. I see that there is a starting battery and a deep cycle(?) battery. What is the difference in the make-up of these batteries? I never run the stereo so I only care about starting, Optima has a blue top that they recommend for marine use that they say does both well...any experience with these?
Indy is offline
Old 08-26-2006 | 10:08 AM
BY U BOY's Avatar
Default Re: Battery advise
I Use Tw Optima Batteries And Have Never Had A Problem Starting The Boat After Hours Of Listening To The Stereo.
BY U BOY is offline
Old 08-26-2006 | 12:36 PM
Strip Poker 388's Avatar
Rob
If it a a stock style motor any regular style battery will work.I bought one from autozone with a 7 year warranty for 70 bucks
I bought some blem exides that look like the Optima blue tops. they were 50.00 each non blem was 108.00 Try and find a Exide warehouse [not dealer] in your area they will sell you direct. I found out that Sam's Wholesale buys from the same place.
Strip Poker 388 is offline
Old 08-26-2006 | 02:31 PM
'05 Concept SF23
I use Optima for starting and a deep cycle marine for house.
f311fr1 is offline
Old 08-26-2006 | 02:51 PM
Indy's Avatar
Member #154
Which Optimas are you guys using?
Indy is offline
Old 08-26-2006 | 03:02 PM
27 series and 24 series have been the standard, Dep Cycle will recharge many more times than a starting, you can also buy a deep cycle starting , see what the Amp are, 500 to 900, 900 are the best, CCA means cold cranking Amps and MCA = marine cranking amps, CCA is figured at 0 degree and MCA is figured at 32 degrees
Good Luck
Don
Racine is offline
Old 08-26-2006 | 03:12 PM
BY U BOY's Avatar
BLUE TOP 27 AND 24
BY U BOY is offline
Old 08-26-2006 | 04:25 PM
Good Luck
Don
Racine is offline
Old 08-27-2006 | 08:54 AM
RJ1340's Avatar
Could you repeat that one more time, Don?
RJ1340 is offline
waterboy222
05-17-2009 03:25 PM
BAJA WILL
02-26-2008 08:12 PM
tpmarine.com
New Products and Member Discounts
4
02-02-2006 09:50 AM
luvlake
0
03-16-2004 04:55 PM
BAJA WILL
05-02-2003 05:26 PM
