Mufflers
Old 09-01-2006 | 09:03 AM
Tazz's Avatar
Default Re: Mufflers
Nykamp, I'm telling you, the downtubes are the way to go. I have staggered #6's with 1000hps, and they work great, no back pressure once on plane. The center exhaust pipes only have 3/4" between them and the clamp-on's fit. They're quiet as hell at idle. I'm not near the boat now, but i will be this weekend, i'll take a picture.
Tazz is offline
Old 09-01-2006 | 10:44 AM
Steve's stagger will provide a little bit of a challenge for down spouts. The starboard, inboard pipe, comes out right over the port transom housing.
Lunatic Fringe is offline
Old 09-01-2006 | 10:49 AM
ApachePete's Avatar
Re: Mufflers
What an ODD configuration!
ApachePete is offline
Old 09-01-2006 | 10:52 AM
Gary,
What is the drop from muffler centerline to the end of the down pipe on the ones you have for sale? I may be interested in those for my Cougar, or modifying my Gaffrigs in a similar manner.
Jim
Old 09-01-2006 | 11:00 AM
RMPRam's Avatar
The dimension from the center of the muffler to the tip of the "down-tube" is 18"
Do you need any other dimensions?
RMPRam is offline
Old 09-01-2006 | 11:10 AM
RMPRam's Avatar
I just looked @ the transom on your Apache.
I believe it would be possible to take the 2 port pipes and "drop" the "down-tubes" to the left of the port drive and take the 2 stbd. pipes and "drop" them to the right of the stbd. drive.
The ex. pipe between the drives would probably have to have the horizontal run of the "down-tube" lengthened a few inches to clear the gimble.
It can be done.
Give me a call and we could discuss it.
Gary Kollofski
ph: 763-473-8963
RMPRam is offline
Old 09-01-2006 | 04:12 PM
offshoredrillin's Avatar
lol, yea who built that thing anyhow?
offshoredrillin is offline
Old 09-01-2006 | 07:52 PM
Ratickle's Avatar
What type of switchables do you have on there now? Did they test with them in the "silent" position? Also, before you spend a bunch, it looks like the law will change, within the next two years max, to where we will also be tested at speed in Michigan (similar to Wisconsin's law), not just at idle.
Ratickle is offline
Old 09-02-2006 | 05:20 AM
Nykamp's Avatar
I am going with the new CMI's 5 by 6's from Fred @ Trick, Thanks Fred. Steve
Nykamp is offline
Old 09-02-2006 | 07:46 AM
BeakBoater35's Avatar
What are "new CMI's 5 by 6's"? Why did you decide on them? I'm looking for mufflers for Mercury HP525SC motors. Appreciate your thoughts.
BeakBoater35 is offline
