-   -   Would you Tie down your boat this way ?? (https://www.offshoreonly.com/forums/general-boating-discussion/140542-would-you-tie-down-your-boat-way.html)
Strip Poker 388 09-15-2006 12:09 AM
2 Attachment(s)
It would have to scratch it :eek: Why not hook it to the eye?
I guess at least he has straps on it.
Strip Poker 388 09-15-2006 12:15 AM
Re: Would you Tie down your boat this way ??
1 Attachment(s)
Better?
Outdrive1 09-15-2006 12:16 AM
takes all kinds......... :rolleyes:
Chris Sunkin 09-15-2006 06:38 AM
Originally Posted by Strip Poker 388
Better?
No.
Strapping 90 degrees off the direction of movement is a waste of time. If you had a problem, the boat would still move. Those straps are rated for a static load, not dynamic. Once the boat started moving, it wouldn't stop. Those straps would pop in a heartbeat.
el indio 09-15-2006 07:02 AM
1 Attachment(s)
try this!!!!!!!!!!!!!!!!!!!!!!!!!
itilldo 09-15-2006 07:13 AM
I think there's room for a few more straps
ratman 09-15-2006 07:46 AM
i do it over the nose like that but use 3/8 chain so it wont break :evilb: it is a little tuff on the paint.
mm, do you own stock in the strap co??? :D
gotime34 09-15-2006 08:00 AM
I think that guy is a member on here...maybe he'll chime in and give his reasoning.
Chris Sunkin 09-15-2006 08:01 AM
That works.
...If the bow eye is reinforced properly. I've seen a couple that have torn out. No backing plate.
sonic28 09-15-2006 08:03 AM
i know i'm goinig to get sh=t for this one.the boat is fine he's supporting the rocket trailer so it does not flex
