Winterizing questions...
Old 10-11-2006 | 10:09 PM
ToTheMax's Avatar
Default Winterizing questions...
I know this forum is for offshore performance boats, but I have a couple of questions for winterizing PWC's. Is it better to winterize with Fuel and Oil tanks empty or full? Aside from battery removal, are there any other things I should do?
ToTheMax is offline
Old 10-12-2006 | 06:30 AM
Default Re: Winterizing questions...
Empty most of the fuel, use stabil for the rest. The oil should be fine.
Magic Medicine is offline
Old 10-12-2006 | 07:54 AM
pkspx's Avatar
Checkout PWCTODAY.com forums
http://server1.sbtontheweb.com/forum...ad.php?t=13977
pkspx is offline
Old 10-12-2006 | 08:32 AM
Chris288's Avatar
I store my Ski's with as little fuel as possible, stabalize whats left, and I fill the oil resevoir to the top.
Chris288 is offline
Old 10-12-2006 | 08:57 AM
If it's carb. you can take as much fuel out as you can and run the carbs dry with the fuel valve off. If it's injected put some stabilizer in it and run it for a while to get stab. in fuel system. Pull plugs and put a shot of oil in the cylinders. Sometimes water stays in the waterbox, so dump a little anti-freeze in it. Pull battery.
rdp145 is offline
rrentsch
49
11-11-2007 10:33 AM
266ltd
9
11-05-2007 07:37 AM
rssteiny
1
10-11-2006 09:45 PM
Rippem
7
10-01-2003 01:35 PM
shinsr
5
10-16-2002 02:07 PM
