New Engines: 557 or 572
Old 10-19-2006 | 09:22 AM
  #91
ratman's Avatar
Default Re: New Engines: 557 or 572
Originally Posted by JCPERF
And according to Smokey, all the rod does is connect the piston to the crank.
don't be hatin...smakey was way ahead of his time you biotches
ratman is offline
Old 10-19-2006 | 09:29 AM
  #92
ratman's Avatar
didn't smokey say there is no substitue for cubic inches?
my new mills are 598ci 4.625 str and 4.530 bore, i figure after a handful of rebuilds they will be square 4.625 X 4.625. im gonna rev then 6200 rpms. we'll see how well the 4 5/8 stroke holds up.
ratman is offline
Old 10-19-2006 | 10:55 AM
  #93
Only because he cheated like crazy!
mrhorsepower1 is offline
Old 10-19-2006 | 01:20 PM
  #94
Strip Poker 388's Avatar
Rob
A different interruptitaion of the rules He was good at it.
Strip Poker 388 is offline
Old 12-09-2006 | 12:22 PM
  #95
MrCIG's Avatar
Charter Member#330
Ok Tall deck 10.2, 4.56 Bore x 4-3/8 crank. What rod Length would you recommend. Naturally aspirated Flat top pistons.
Mark
MrCIG is offline
Old 12-09-2006 | 01:36 PM
  #96
Viper31's Avatar
These 557s that make 1100HP went 178 hours since i built them with the big lifters and Isky springs.And they got murdered too.
JC, did you use Isky roller lifters on those mills?
Viper31 is offline
Old 12-09-2006 | 01:58 PM
  #97
RHC's Avatar
RHC
It ain't cheatin if ya don't get caught!!!!
RHC
RHC is offline
Old 12-09-2006 | 02:45 PM
  #98
RHC
True Roger......but it sure is nice when you don't have to and still win!
Old 12-09-2006 | 05:24 PM
  #99
Originally Posted by GPM
If it's the light weight block you might not want to use it.
How do you tell if you have a lightweight block? What is wrong with it?
flat rate is offline
Old 12-11-2006 | 02:32 PM
  #100
Mark, id go 6.635. Happy b- day. Brian
scarrab30 is offline
