High end boat stereo question >
Old 10-25-2006 | 08:25 PM
Charter Member #415
Default Re: High end boat stereo question
Going to plug in the shore power,turn on the built in battery charger for a few hours,then see if there is still feedback. If so, it is not a battery problem.
Magicfloat is offline
Old 10-25-2006 | 08:27 PM
dukenrock's Avatar
http://www.installdr.com/TechDocs/999502.pdf
My guess is a grounding issue
dukenrock is offline
Old 10-25-2006 | 08:52 PM
Charter Member #415
Thanks,Kevin. My thoughts exactly.Kind of like if I pay a plumber what he asks to fix my toilet and it still doesn't flush,it's his problem to make it flush,not mine.
Old 10-25-2006 | 08:55 PM
hunster's Avatar
Just remember that battery charger will most likely put a ac humm over the stereo. Turn it off when testing sound quality. With the batts fully charged you should get some time to test before they flatten a bit depending on how many amplifiers and wattage.
hunster is offline
Old 10-25-2006 | 09:42 PM
BY U BOY's Avatar
If You Don't Find A Problem With The Rca Cables Or Power Source Pull The Amps And Have Them Bench Tested. It's A Possibility That The Amps Or Amp Has A Bad Power Supply.
BY U BOY is offline
Old 10-25-2006 | 10:13 PM
It sounds like you have a "ground loop" issue, which means two grounds with different resistances. Try grounding the radio with the amplifier ground. For temporary purposes, run the stereo ground wire straight to the amplifier ground terminal at the amp. If the noise goes away or gets better then that is the problem. You don't have a voltage issue.
Sight and Sound is offline
Old 10-25-2006 | 10:15 PM
Charter Member #415
Thanks for the help guys. Another example of the power of OSO. Will let yall know what my stereo guy finds. Thanks.Robert
Old 10-25-2006 | 10:19 PM
dukenrock's Avatar
Old 10-26-2006 | 12:45 AM
sleek1's Avatar
It's not the batteries, make sure you have a solid CLEAN ground.
sleek1 is offline
Old 10-26-2006 | 03:47 AM
jordy's Avatar
Originally Posted by BY U BOY
Add A 1 Farad Cap That May Wor`k If It Is The Voltage.
Wow, so caps magically create voltage???
jordy is offline
