hull paint ??
Old 11-14-2006 | 09:15 PM
BigSilverCat's Avatar
Default hull paint ??
what bottom paint would you put on this? it is a 91 hull on a fresh water lake, the lake is reasonably clean, should I use a soft paint that wears away and how often do you have to do that?
Attached Thumbnails hull paint ??-august-10-06-008-medium-.jpg   hull paint ??-august-10-06-011-medium-.jpg   hull paint ??-august-10-06-004-medium-.jpg
BigSilverCat is offline
Old 11-14-2006 | 10:16 PM
Mac's Avatar
Mac
Default Re: hull paint ??
Speedcoat!
Mac is offline
Old 11-14-2006 | 10:30 PM
blume's Avatar
Interlux bottomkote, it will last for 18 to 24 months. On that boat you might want to put a barrier coat to help seal it from blistering?? and maybe some Interlux Micron CSC, it's a little more expensive but worth it, it will last a little longer also.
blume is offline
Old 11-15-2006 | 12:03 AM
Strip Poker 388's Avatar
Rob
Looks to be a Blue Water ? They might give ya some extra insight?
http://www.bluewateryacht.com/performance.htm
Strip Poker 388 is offline
Old 11-15-2006 | 01:06 AM
I would paint it white but don't paint over the original Apache sticker on the side...
Fanatic is offline
Old 11-15-2006 | 11:30 AM
madbouyz's Avatar
White's nice , but none of the new stuff is actually 'white' ... more like 'cream' or some other variation.
I would do it Awlgrip's 'bright blue'.
Awlgrip make a killer bottom paint (even for salt water) and the bright blue will make that BW look much nicer .
I have this thing about black bottoms ...oops , is that politically correct
madbouyz is offline
Old 11-15-2006 | 01:18 PM
might also check with these guys.
http://www.yachtforums.com/
Finman
FINMAN is offline
Old 11-15-2006 | 02:19 PM
who has good prices on awlgrip?
Old 11-15-2006 | 08:22 PM
Scott B's Avatar
I could help ya with Awlgrip, but shipping mught be a bear... PM me a zip code and I'll check shipping for you..
Scott B is offline
Old 11-15-2006 | 08:29 PM
Go with a good ablative .And put on three thick coats that are a different color than what is on there so you can see when it is time to recoat.Easy to recoat just pressurewash clean and recoat.
tommymonza is offline
