Cat Length question
I was told that water is something like 800 times denser than air, so a boat with 2-1/2" of less wetted surface should have a speed advantage in flat water over a longer boat with the same OAL to tunnel length and attack angle/compression ratio.
I think....
I think....
Originally Posted by warbird
after reading all your "rocket science" replies, I've concluded that most of you should be more worried about your 2/12' shortages in another place...
I think....
I think....
does that really effect the running surface?and you are right, dry air at sea level is 1/800 the density of water (approx)......
I'll take it !!
Say the boats are running 100 MPH
Race lasts 1/2 hour
I win by 1/4 mile....
Race lasts 1/2 hour
Less aero drag = good
Less aero lift = bad
less direct hydrodynamic surface drag = good
less lift = less dynamic buoyancy = more drag = bad
It's a wash. Net result = approximately zero.
Let's put it this way, those 2.5 inches will amount to whether or not you emptied the change in your pockets.
I'll take it !!
Race lasts 1/2 hour
Race lasts 1/2 hour
