what mufflers?
Old 11-25-2006 | 08:46 PM
Default Re: what mufflers?
I havn't heard of any of the mufflers holding up with big motors and no water. If anyone has any info to the contrary please post it. I have 6" totaly dry cmi and over 1100 hp to quiet down.
Hey Ratickle did you get my reply on the Flame Arrestors ?
Paul
427eliminator is offline
Old 11-25-2006 | 09:02 PM
TeamSaris's Avatar
Driver-441
Racer
Paul
stellings
We have them on 1300hp motors and they pass at under 90dbs
TeamSaris is offline
Old 11-25-2006 | 10:17 PM
I used Corsa mufflers on two boats successfully, and never lost top speed. I replaced the Corsa's on my current boat because I wanted to try and get even quieter, and switched to Gibson bullets. The Gibson's may be very slightly less loud, but because I also upgraded the engine, I don't have a perfect before and after comparison for noise or top speed. This may not be the correct place to mention this, but I have the Corsa's for sale. They are thru-transom mounted for a 4" exhaust hose. They have 6 1/2" diameter bowls that Corsa says are good to 600 HP with no performance loss, and also have external salisbury flappers. I used them only one summer and they look like new. I'd be happy to get $300 for them.
Escape Velocity is offline
Old 11-26-2006 | 07:50 AM
scarabman's Avatar
Due to the configuration of my exhaust set up and water exit, I definitely need to use clamp-ons. This is what seems to be limiting my options. thanks anyway though.
Nobody running or have any experience with Shotgun type set ups?
scarabman is offline
Old 11-26-2006 | 09:53 AM
wrinkleface's Avatar
I have the Livorsi E-Series on my 525's. Like them alot. Quiet at idle and then growl while running! Good luck.
wrinkleface is offline
Old 11-26-2006 | 04:19 PM
scarabman's Avatar
The Livorsi's are a good unit however they are not recommended for my set-up due to where the water mixes in.
The Gibson downturns would definitely work however I think they will be too quiet for my taste. Still want to hear a little growl at idle
Old 11-26-2006 | 04:47 PM
Too Old's Avatar
Livorsi no longer sells the E-Series. They now sell the CMI Sound Elimination Mufflers.
Too Old is offline
Old 11-26-2006 | 06:23 PM
'05 Concept SF23
I think Lofty on here has access to GGB. I run them on 600 CU IN 750 HP NA and they work great. could not tell any difference from before and after except a little rich in the mid range.
f311fr1 is offline
Old 11-27-2006 | 02:51 PM
Lofty's Avatar
GGB is no longer producing marine products. A very similar product will be on the market early in 07'. It's a exploits the same technology as the GGB's with some real improvements to construction. We are promised the first production run in January.
Lofty is offline
Old 11-27-2006 | 06:33 PM
scarabman's Avatar
Lofty,
Can you provide more info on these upcoming units? Pricing? Available in clamp-on? Will they work for my described set-up? thanks in advance.
Regards, Mark
